FS: Mickey Thompson ET street drag pack.
Old Oct 17, 2011 | 03:50 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Selling a set of 40% used 265/40/18 ET street drag tires. These are DOT approved stret tires and belted tire. This is a rear set only and comes wth 18x9.5 rims, so you can switch back and forth from track, street racing or weekend cruising. Will ship anywhere in the continetal US for fee. Need 450.00 firm for the set of wheels and rims.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 21, 2011 | 01:44 PM
PLATINUM SPONSOR
2003 CL55
This a great deal for anyone wanting to run on the street andalso change tires for the track. Just PM me!
__________________
www.ultimatepd.com
Old Oct 21, 2011 | 06:27 PM
320 dreamer's Avatar
2003 porsche 996 turbo
offset?
Old Oct 31, 2011 | 01:57 PM
PLATINUM SPONSOR
2003 CL55
I made a mistake in my tittle.. Rims are 18x9 ET44 not 18x9.5 as stated in tittle
__________________
www.ultimatepd.com
Old Nov 1, 2011 | 02:33 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Might want to post in the wheel and tire section.
Old Nov 1, 2011 | 09:54 PM
whats the tire and rim combo weight?
Old Nov 2, 2011 | 12:37 AM
AKnight55's Avatar
Not light.. I have this same set up. Prob around 55 lbs
Old Nov 2, 2011 | 06:25 AM
400RWHP's Avatar
2006 CL600
So this setup will fit W211 E55?
Regards
Old Nov 2, 2011 | 09:17 AM
PLATINUM SPONSOR
2003 CL55
58 lbs my UPS scale.
__________________
www.ultimatepd.com
Old Nov 2, 2011 | 09:18 AM
PLATINUM SPONSOR
2003 CL55
Regards
Yes it will fit, you may need a spacer if you want less offset.
__________________
www.ultimatepd.com
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
