Injectors, Wideband, Injector Adaptors, NA M113 Pistons/Rods
Just a couple of months old, this wideband system is easy to install and very easy to read. Comes with everything as it did when new, sensor and wiring harness, PC connector, etc. Does not include gauge pod pictured. Sells for $160 shipped new, I'll sell it for $110 shipped.
Use these to run injectors with EV6/EV14 plugs on your AMG. The set of 8 costs $80+shipping on fiveomotorsports but I'll give them up for $50 shipped, nearly half off for something that doesn't even wear out. Here is a link for more info on them:
http://www.fiveomotorsport.com/uscar...ical-connector
Pistons and rods came from a 2005 C55 AMG. They are in perfect shape ( just the obvious carbon buildup ) and were swapped out for a lower compression setup for forced induction. These pistons have an 11.1:1 compression ratio. Rings and bearings will need to be replaced. Rods are forged ( fractured split ) and pistons are Hypereutectic. $250 shipped
