2003 E55 "BRAKESTAND BURNOUT" TCU.... for 2005-2006 E55
Old Mar 5, 2015 | 04:20 PM
GregMB's Avatar
Here it is!
Part Number: A 033 545 14 32
This is the OEM TCU for 2003 E55s, which does not limit brakestanding burnouts like the later 2005 - 2006 TCUs.
As originally discussed at length on the MBWorld forums, there are only a few TCUs that will allow for unlimited brakestand burnouts.... here is the original table that highlights the differences by model year.
$200 + the ride.
-G
Old Mar 10, 2015 | 08:38 AM
cmattox's Avatar
18' AMG GTR, 05' E55
I'll take it for $150 shipped to 92627 if you want to get rid of it
Chris
Old Mar 10, 2015 | 10:34 AM
uraberg's Avatar
2006 E55 AMG
Is this plug and play, or does it need to be version coded?
Old Mar 10, 2015 | 10:36 AM
GregMB's Avatar
This is an "EGS52"... no version coding necessary for the E55.
-G
Old Mar 10, 2015 | 08:01 PM
uraberg's Avatar
2006 E55 AMG
From reading around, so far, this is my understanding. Please correct me if I'm wrong. I think it would be neat to do a little burnout every now and then, but I'm skeptical.
EGS52 just means that the TCU is programmable, it does in no way imply plug and play compatibility with my car.
If the TCU is pulled from any platform but a w211, version coding is necessary.
I've seen one post where someone swapped to an earlier TCU, and was still unable to spin the tires.
Since it is a relatively small job, would you mind plugging the TCU into your car, to verify that it actually works?
Thanks.
-G
Old Mar 11, 2015 | 07:06 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
I believe the 2003's had to be matched TCU with valve body & the steering wheel shifters only worked when in manual mode, while in later years they worked in any mode.
Old Mar 16, 2015 | 02:37 PM
GregMB's Avatar
TTT
Old Apr 1, 2015 | 04:09 PM
GregMB's Avatar
SOLD!
