EQE SUV (X294) Forum for Discussion of EQE SUV
Light Settings Turning off Overnight?
Old Feb 3, 2025 | 07:56 AM
manjurino1's Avatar
2024 EQE 350 4matic / 2019 911 Carrera T
Good day all,
Wondering if anyone is running into issues with the light settings reverting off over night.
I turned on all the setting and in the morning and they revert to the off setting the next morning.
Includes the following:
Ambient Light - Either completely off, or at the standard blue setting (white was chosen on my end)
Under Operating Feedback: Charging, Voice Assistant, Climate and Welcome lights, turned off
Under Warning Support: Active Lane Keep Assist, Blind Spot Assist, Active Brake Assist, Warning when Exiting, turned off
Under Digital Lights: Dynamic Low Bean, Spot Light, warning and Alerts, turned off
Under Exterior Lights: Locator Lighting, Turned off
I did try to reboot MBUX by holding the power button for 10 seconds, and that didn't help. Perhaps there is some issue that I am not aware of?
Old Feb 3, 2025 | 08:19 AM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 2015 E250 BlueTEC 4MATIC, 1995 E300 Diesel
If you switch profiles, or use no profile, it's possible these settings may change. Make sure you're signed in to your desiredbprofike before you make the changes, and they should hold. I do have a couple of settings that seem to clear themselves roughly every 3 months or so, but generally everything sticks.
Old Feb 3, 2025 | 08:23 AM
manjurino1's Avatar
I can confirm that the correct profile is active. I had the same issue a couple days ago, and it held the settings for a day. I jump into the car today, and all the settings were cleared.
Old Feb 3, 2025 | 12:14 PM
Try a full reset of MBUX. You can do so in system settings. Hope that helps!
Old Feb 11, 2025 | 11:17 AM
manjurino1's Avatar
Just wanted to say thank you. a full reset stabilized everything on my end. Appreciate the help!
Old Mar 1, 2025 | 03:42 PM
nosnoop's Avatar
535
Unfortunately, it looks like there is a glitch in the system.
My lighting setting would also turn off like yours from time to time randomly - just like the favorites going blank.
It doesn't happen very often, but it is annoying as hell when it does.
I think you need a full software update, which I hope would fix this problem.
I am collecting all the glitches and would request a software update later.
Old Mar 2, 2025 | 03:47 AM
ScottC2's Avatar
2023 EQE SUV 500 4Matic
The only time I've ever noticed any behavior like this on my car is immediately after an OTA or dealer MBUX update...which didn't surprise me.
But to have it happen at any other time, I agree, would be annoying and should not happen!
Old Mar 4, 2025 | 07:34 AM
manjurino1's Avatar
Yes, the full wipe of the MBUX system did work for a few days. One draw back was the siriusXm tiles were not loading on the screen. That was corrected with the a signal refresh for the satellite radio.
Car is currently in service and they are going to update the software. I will report as soon as I get the car back.
