EQE SUV (X294) Forum for Discussion of EQE SUV
12V Battery?
Old Apr 28, 2025 | 05:59 AM
Scott Schmidt's Avatar
GLS 450 (2022), EQE SUV 350 (2025). GLS 450 (2007)
12V Battery?
Hi folks. I've got a 2025 EQE SUV 350 and have read that in addition to the main propulsion battery, this vehicle also has a conventional 12 V battery. Can anyone tell me where this is located in the vehicle and what its intended function is? Also, assuming that it does actually exist, is it charged by the main battery or by the wallbox charger? Thank you very much.
Old Apr 28, 2025 | 07:03 AM
ScottC2's Avatar
2023 EQE SUV 500 4Matic
The 12v battery is under the hood on the passenger side (US) of the car.
It is charged by the HV battery
In general, it provides power to all things that are not propulsion-related. Most importantly, it's needed to START the car.
Old Apr 28, 2025 | 07:05 AM
Thank you!
Old Apr 28, 2025 | 07:14 AM
ScottC2's Avatar
Old Apr 28, 2025 | 07:17 AM
ScottC2's Avatar
Old Apr 28, 2025 | 08:47 AM
W205C43PFL's Avatar
Another tip is also scanning the rescue card for all the electricals.
Old Mar 7, 2026 | 05:38 PM
R230king's Avatar
2011 SL550
my car ended up sitting for a bit because of my brakes, before that I had just replaced the rear battery but was still getting a red battery sign and not all the electronics were working, anyone know whats causing this? currently none of the inside lights work and locks nor does the automatic window, it just stays slightly down when i shut the door
Old Mar 8, 2026 | 03:43 PM
Egonvdv's Avatar
EQE SUV AMG-line 350+
does this mean i can hook up a dashcam to it and basically have unlimited power ?
Cos It seems the car also charges the 12v battery when parked, but i don't know if it stops doing that after a certain amount of park time ?
Old Mar 10, 2026 | 12:57 PM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 2015 E250 BlueTEC 4MATIC, 1995 E300 Diesel
The car will not regularly engage the DC/DC converter to charge the 12V battery. That said, if you approach the car and the it "wakes up" because of your key, and the battery is low, it *will* engage the DC/DC if the battery is critically low. Overall, I wouldn't recommend any consumers on your 12V unless you drive daily, and even then, it may not be as advisable.
Old Mar 11, 2026 | 07:24 AM
Egonvdv's Avatar
Thanks .
Seems there are mixed opinions about this .
Some people say it won't tax the 12v battery, others say it does.
Maybe better not to mess with my current setup (battery pack) , which gives me at least 4 days of park mode
Old Mar 11, 2026 | 07:33 AM
ScottC2's Avatar
I think that's a wise approach. These cars seem to have enough quirks and misbehaviours even coming direct from the factory, without customer modification. Sigh...
Old Mar 11, 2026 | 07:35 AM
Egonvdv's Avatar
Very valid point!
Old Apr 22, 2026 | 02:47 PM
ronin amg's Avatar
2024 EQE AMG SUV . 2021 GLE AMG 63s Coupe
After having some issues with my 12 vt battery I decided to be pro active and add a bluetooth 12 vt monitor so that I can see the battery condition in real time in order to see if it is charging correctly.
This works like a charm...
Amazon Amazon
