Pre Conditioning HV Battery
I am a bit confused and hopefully someone can chime in and help. I am going on a small road trip and expected weather will be below zero (F).
My plan is to preheat the cabin about an hour before departure while connected to the level 2 charger in my house.
Does this set up actually warm up the HV battery? If i am understand this correctly one off the largest loss in consumption is the actual warming of the HV battery?
Perhaps someone can help me understand if my logic is correct?
TIA
Pre heating of the battery is performed when Intelligent Navigation is active and a high speed charging spot, on route, has been identified. The system will warm start the warming of the battery at the appropriate time prior to arrival and the start of charging. You cannot manually set or activate the battery conditioning.
Please forgive me, I know heating and cooling is a huge energy drain, but does the HV battery preconditioning use as much energy (thru the Intelligent Nav)?
I am trying to understand when they say pre condition the cars on cold days to maximize the range. Clearly that is to offset the energy loss from heating/cooling cabin.
I know the HV battery has a difficult time with the cold, but is the car using energy to warm the battery while driving, or is that activated only during request via Intelligent Nav
Knowing that pre-conditioning of the interior does not include battery warming then there is very little additional control opportunities. Pre-conditioning the car while it is plugged in will provide additional range, rather using energy from the battery to perform the initial heating/cooling of the interior.
The car may be using some energy to make sure that the battery is in optimal condition but you have no control over this. The battery will take longer to charge on a high speed charger In cold conditions if the battery has not been preheated. Using Intelligent Navigation is the only way to activate this function.
If you need to stretch the range in very hot or cold conditions then drive in ECO mode, avoid driving at high speeds, and limit the use of heating or cooling of the interior.
Considering that you have paid big bucks for a high end vehicle make use of its features and do not sweat the small stuff. Having to make one or more 15-20 minute charging stops on a long drive and what this may cost compared to how much the car costs should be trivial. Just drive and enjoy.
How much would it change the Battery Temperature when You set your final Charging Time ( I guess 100% for a Road Trip) to the departure Time. Not the Preheating, I’m talking HV Battery Recharging.
Should't that give the Battery some Temp to be happy when ready to take off?
Thanks, HF.
Thanks, HF.
The Thread Starter was asking about the Point of time while Home Charging still plugged in. Not while driving.
My Thought or Idea was to help with HV Battery Temperature while Home charging. In Eco Charging mode one can set it to have the car finish Charging at a set Time. If You set that to the Trip Starting Time, the Battery should be doing still some last bit of Charging and thus keeping the HV Battery Temp at least a bit higher that 0F.
The Cabin Temperature Pre-Climate control is a separate entity. Only Question here would be, Is the Car taking all Energy needed for preheating the Cabin from the Home Power source straight or looped through the Battery thous warming it a bit too.
