EQE Sedan Braking / RAIN
Anyone else have this issue? And no, the car was not hydroplaning or anything like that, i was not in water or a puddle, just a wet street and going to a stop sign after the car was parked in the rain for 24hrs each time.
If you were in "intelligent recuperation", it's possible that the car decided to stop slowing due to a condition in the road (e.g., no traffic, or it thinks you're ignoring the intersection). While I completely understand why intelligent recuperation does what it does, it is a bit "wrong thing at the wrong time" for me, or at least, it doesn't always mirror what I might do in that situation. For that reason, I use "no recuperation" to maximize coasting, and to use as much regen as possible when I do apply the brake pedal.
If you can give us a bit more background, we may be able to shed some light on it.
The popping sound could be the brake pads having been a bit stuck while it was sitting in the rain - if you were mostly regenerating before, there probably wasn't much pad application. On our SUV, after dirt and salt buildup, you could hear the pads click and clack back and for just a bit when stopping at a stop sign or reversing. It went away after I washed the car - the brake pads float on the guide pins.
The first time ABS kicked in for me on a brake-by-wire EV (in the EQE sedan during the summer, I went over a pothole and rough surface on dry road, causing ABS activation), I was a bit surprised, but learned quickly that the brake pedal indeed goes down a bit to let you know "hey, you're not stopping normally, you're in ABS braking now". The car feels like it's not stopping as quickly, as during ABS activation it works to prevent spinning out and wheel lockup during activation. This actually very much feels like the lunge you described - you went from strong deceleration to much reduced deceleration during ABS operation. Then, as wheelslip is normalized, the deceleration resumes more strongly again. It'd feel the same on a standard non-brake-by-wire car, but you'd have a different pedal feel. Once you're used to it, it'll feel normal. This also mirrors perfectly what you said - when you let go of the brakes, this allows wheels to resume traction, and then you re-applied brakes and decelerated more strongly again. ABS does this much faster, and in net, you'd have stopped faster if you'd just simply held the brake pedal than letting go and re-applying, once the system figures out the updated split-mu traction situation.
Some people rightly get surprised that during ABS activation, the car slows down much less than during normal brake usage. Thing is, if it didn't, and you have split-mu traction (different friction coefficients at different wheels), the braking force by wheels with strong traction would actually cause your car to yaw violently and you'd spin out. So, ABS application (and ESP, for that matter), is a very carefully balanced dance of stopping you as fast as possible while maintaining control.
I will say that if you had any brake issues whatsoever, the car would immediately throw a code. These brake-by-wire systems are highly sensorized and redundant, I strongly suspect you didn't have a failure, just a different regime of operation.
you sir are spot on... I have turned one year with mine and the brakes still suck. They grab and then let go and grab again and in the rain (FL here) they are unpredictable. Funny on our EQS SUV its not bad.
I don't know about the EQEs but I have no issues with the EQS brakes. Even the moving brake pedal that some of the interwebs influencers don't like.
