EV Owner Charging Advice Needed
Do you use a type 2 wallbox or the MB type 2 cable and a 240v nema 14-50 outlet?
Do you regularly charge at public level 2 or level 3 chargers?
If given the choice, would you buy your EV again?
I'm planning to order a MB EQE next year when the body style changes from its jelly bean shape to a regular E class body.
If I can use an existing50 amp dryer outlet I won't have to obtain unit owner & condo permissions, city permits and an electrician
to add an additional power feed and panel dedicated to EV charging ($$$).
I have an EQE SUV, but my answers should still be relevant for you.
Do you charge at home? Yes. 90% of my charging occurs at home. I am in a condo and the condo association decided to install wall boxes in all of our parking spots at once with a load-balancing system to share power equally to the cars but still leave enough power for the condo units. The balancing system also makes sure our power draw, in total, does not hit the limit of our power entrance. As such, we did not need to upgrade the power entrance and power contract with the electric company. It's saved us and our association a lot of money.
Do you use a type 2 wallbox or the MB type 2 cable and a 240v nema 14-50 outlet? I am in Sweden. 11kw/h non-MB Type2 (European) wallbox. I understand from reading posts on this forum over the last couple of years that you likely cannot expect anything over 9.6 kw/h in the States from a wallbox at home.
Do you regularly charge at public level 2 or level 3 chargers? My car has the option to charge at 22 kw/h AC chargers, but I never use it. Typically when I see these chargers, there are 100/150/200/350 kw/h DC chargers at the same location and I use these to save time because I'm on a road trip.
If given the choice, would you buy your EV again? Absolutely, positively YES! Though next time, it could be a GLC (EQ) for me.
There's a lot of charging discussion on this forum. Search around. Read around. I've seen quite a number of posts indicating that using a 240v dryer outlet may work, but it can be a huge fire risk. The outlet (and perhaps the wiring??) for a dryer installation are not designed or dimensioned for such a high, long and constant power draw. Based on what I've read, I would absolutely not try this.
- charging is in my underground condo parking space using a commercially installed connection arranged by the condo. It provides a max of 6.4kw/h which is quite adequate for overnight charging.
- it is a Type 2 wallbox managed by SWTCH that provides a keycard to authorize charging
- the majority of my charging is at home. Out of town trips are usually booked for hotels that provide free Level 2 charging. I very infrequently use a public charger and it would be at a DC fast charger.
- EV's are rapidly evolving, so buying the same one again may not even be possible, but I would not buy an ICE again. The convenience of charging at home and reduced maintenance is such a pleasure.
1. I've used a DC charger 1 or 2 times when I was experimenting on the charging infrastructure. So about 99.9% of my charging is at home.
2. My charging unit is a Wallbox Pulsar Plus, which is hardwired into the main panel in the garage. I believe that the unit is also configurable to use a 50-amp outlet. However, I would upgrade your dryer outlet to an industrial version to avoid meltdown and fire..
3. I believe that the EQE SUV is at the end of its life. The replacement appears to be the 2027 GLC SUV with EQ, which has nearly identical interior and exterior dimensions.
4. I definitely don't miss going to a gas station, the cost of premium gasoline, and the yearly maintenance items of oil changes, etc. My energy costs are at $0.11 / KWH from Duke Energy here in NC. During the 23 months of ownership, I have saved over $ 2,000 by not using gasoline. I would definitely buy another EV again, and I'm planning to do so at the end of next year.
2027 GLC SUV with EQ Technology | Mercedes-Benz USA
The bottom line is that using public chargers costs a magnitude more than home charging. Duke Energy Florida has Super Off Peak rates of 4.806¢ per KWh in addition to other incentives.
Going forward we will mostly charge at home but will use public chargers on the longer trips (i.e., greater than 200 miles). We also rent EVs when we travel, those we charge at public chargers.
As for would I buy an EV again? Yes, definitely. I wish I had gotten it much sooner than I did. Electric drive is far superior to internal combustion engines. It really is no comparison. Not having to change oil and filters every six months, not having to go to smelly gas stations, etc., it is just a better experience all the way around.
Edit: I should add that I switched my electricity plan to an EV plan that gives heavily discounted rates from midnight to 3:00 PM each day, and set the car to charge during those low rate periods.
On road trips I have picked hotels with Level 2 chargers, but other than that I rarely use a public level 2 charger. On longer day trips I have charged at Level 3 public chargers.
I've owned only EVs (Tesla, BMW, MB) for ten years and won't ever return to ICE.
How did you manage to remove the restrictions? - my paid version of adobe won't let me do it for some reason ...
Most of my charging is at home. While fast charging is great, and on our road trips fast charging has been a great experience so far, nothing beats having your car ready to go every single day. No planned trips to fuel or charge, it's just ready every day, and unless I have a road trip in the plans, the 70 or 80% charge I've set it to will work for all my daily commute and errand activities.
We have a hard-wired MB (EVBox) charger and another MB (EVbox) charger that is attached to a 14-50 outlet.
If it's convenient and the stations aren't busy, I'll occasionally charge at a level 3 if I'm shopping next to the chargers and know I won't incur idle fees. I always L2 charge at my destination if it's available, because why not? ABC. Always Be Charging. And on road trips, of course, I will use L3 charging.
3000% yes. I love our EQEs. We've had combustion MB vehicles in our family since the 1980s. I currently have two combustion MBs, one a classic (W124) and one W212 that's a project car (a car I have bought back after many years), in addition to our EQE sedan and SUV. But the EQ series is simply spectacular. I've never been so happy to drive a car every day than these. Yes, there are some quirks, and some cost cutting maneuvers that are obvious, but the EQE package is simply fantastic. I know there are faster-charging cars. I know that there are longer-range cars. I know there are more modern drivetrains available. But I feel that the EQE is a very under-celebrated, truly excellent car, and in every way a Mercedes-Benz. What else is there to say? If I had to do it over, I'd buy it again in a heartbeat. In fact, I'd have bought it even sooner if it had been possible, though I did take delivery of my sedan in May 2023, which was pretty early in its availability cycle in the US.
Hope that helps!
Would I buy another EQE? Yes, and I did just that. I initially leased a 2023 EQE 350+. I used the MB lease pull ahead and moved to a 2024 EQE 500 and could not be happier. The car is loaded (101k MSRP) and has loads of power, more than I need really. But they priced these things to move so I took advantage.
