EQE (V295) Sedan Upcoming
Auto Stop Error
Old May 9, 2026 | 02:51 PM
stc1996's Avatar
2022 E350 4Matic
Auto Stop Error
Getting auto stop is disengaged and then error saying it’s no longer available. Any help? Have service set for next week.
Old May 9, 2026 | 08:34 PM
Alexie's Avatar
Common issue. Try cleaning the hood latch sensor first it’s a known trigger for that error. Also check your battery voltage. Low battery confuses the auto stop system. Service will likely find a bad auxiliary battery or a faulty hood switch.
Old May 9, 2026 | 10:18 PM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 2015 E250 BlueTEC 4MATIC, 1995 E300 Diesel
By this do you mean active brake assist? Make sure front radar is clear of dirt and debris, as well as the stereo cameras. Then lock the car for at least 5 minutes and then restart. It should clear. Sometimes when starting the car, it finds an implausible radar scenario and throws an error. It clears on a full power cycle of the system.
Old May 10, 2026 | 08:03 PM
stc1996's Avatar
2022 E350 4Matic
Where are all those cameras and sensors?
Old May 10, 2026 | 08:27 PM
The main one to check is that the MB star in the grille is relatively clean. There are two more sensors in the bumper, so you want to be sure it's not absolutely caked in mud, debris, or other dirt. And then the camera array that you can see at the top-center of the windshield. The wipers usually do a good job of keeping this clean. Hopefully the 5-min poweroff fixes it otherwise.
Old May 11, 2026 | 07:36 PM
stc1996's Avatar
2022 E350 4Matic
Did a run via the car wash and also cleaned by hand, still getting the error. Guess the dealer on Thurs can let me know what needs to happen.
Old May 11, 2026 | 08:11 PM
Any chance you have a photo of the error so we can assist?
Old May 11, 2026 | 09:19 PM
teksurv's Avatar
2024 EQE 500
I'm not sure if this is the same error, however I just had this resolved at my dealer. The resolution was replacing the steering wheel due to failed sensors.
Old May 12, 2026 | 10:46 AM
ScottC2's Avatar
2023 EQE SUV 500 4Matic
Wow. It boggles my mind how this error required a steering wheel replacement to resolve!
Old May 12, 2026 | 11:28 AM
ua549's Avatar
The wheel itself has integral capacitance sensors to indicate if one is touching the wheel. There are integral thumb controls for various menu functions. If one of the sensors or controls stops working the wheel must be replaced.
Old May 12, 2026 | 12:37 PM
ScottC2's Avatar
Yes - but what I find amazing is that any of these sensors have anything to do with "Active emergency stop assist". Seems to me like that should be an entirely separate system!
Old May 12, 2026 | 12:44 PM
W205C43PFL's Avatar
I am wondering if it is because they communicate with the active emergency stop assist and engages it if it detects that the driver is not responding, paying attention.
Old May 12, 2026 | 01:05 PM
ScottC2's Avatar
Ah, yes. That must be it!
Old May 12, 2026 | 03:05 PM
W205C43PFL's Avatar
All systems work hand in hand
Old May 12, 2026 | 04:37 PM
stc1996's Avatar
2022 E350 4Matic
Rhese
The 2 I am getting as I turn on.
Old May 12, 2026 | 04:52 PM
Rhese
Thanks for sharing. Definitely needs to be checked with the dealer's SDS. Likely radar, camera, or other malfunction. We had an issue on my wife's EQE SUV where the ABS tone ring was rubbing against the hall effect sensor. Eventually, it produced an implausible reading, and all sorts of things disabled, including rear steering. It was a quick fix. Without more information from the car directly, it'll be impossible to diagnose, but should be easy to remedy.
