L2 home charger
Got a few questions on the L2 home charger that you will use. Please keep in mind that I'm a first time EV owner "to-be" so I have no experience with charging, but a bunch of my neighbors have Tesla or Taycan so I have picked their brains as well.
1. What charger do you recommend? I'm looking at this one: https://ev-lectron.com/collections/l...arging-station
2. Should I go hardwired or 14-50 plug?
3. I think the circuit should have a 60amp braker to charge at 48amps, but what amperage do you usually charge at? Any heating issues on the cable when charging at high amps? I have recently heard about Porsche telling all their owners to reduce the charging amps because of issues with high amp charging with their devices.
4. Does the Mercedes app have the ability to regulate what amperage the car is charging at, so I can charge at 30amp for a normal overnight charge if I have enough time? Or do I need to make sure the home charger itself has the ability to regulate the amps via their app (e.g. chargepoint charger)?
5. Is it recommended to charge at lower amps?
6. The Tesla charger that came with my neighbors car (Tesla mobile connector) has the ability to switch out the plug cable so you can charge at 120V (12A/16A) or 240V(12A - 32A). I think the Porsche charge is similar. Anyone know if the Mercedes charger option is a similar charger?
Any other things that I should be aware of?
After watching numerous reviews, I selected the ChargePoint Home Flex.
https:/www.chargepoint.com/drivers/home/chargepoint-home-flex
The EQS SUV has a maximum AC charge rate of 9.7 kW per hour, so a 50 amp circuit is all you need or could use. You can order it with a NEMA 14–50 or a NEMA 6–50 plug. Only three wires are required for the charger so the 6–50 plug makes more sense. I ordered the 14-50 plug because I didn’t realize only three wires are needed. It can be hardwired if you’d like but if you go with a plug, it will be easier to replace if something happens to it.
The ChargePoint home flex can do 60 A but once again, the EQS SUV has a maximum charge rate of 9.7 kW so you would be wasting money to install a 60 amp circuit and heavy duty 4-gauge wire.
I haven’t found a way to regulate the charge rate from the app or the car but the charge point home flex is configurable so if you wanted to lower the charge rate to something less than 9.7 kW per hour, it can be done.
Yes, slower charge rates promote better battery health.
You can plug it into a 110 outlet. I will double check tomorrow if it can be plugged into a 220 NEMA outlet.
You will need to buy 6-gauge romex wire to run from the 50 amp circuit breaker to the charger. Once again, you only need three wires to wire it from the circuit breaker to the charger.
2. I prefer hardwired because it reduces the connections in the system (no plug) and likely generates less heat. There is no reason to need to unplug one of these units.
3. You need a 60amp breaker for 48amp charging, or 50amp breaker for 40amp charging. Basically you can charge at 80% of the breaker value. 48amp charging is probably more than you need unless you are regularly coming home almost empty and need a full charge in the morning. Save some money and go with a 50amp/40amp setup.
4. I haven't seen a way to change the charging amps through the EQS MBUX or app, but many of the chargers (JuiceBox for example) you can change the amperage through their app. Kinda annoying but makes it easy to adjust.
5. I typically charge at 16-24amps and then up it to 40amps if I need to charge faster. That is a rare occasion. No need to stress the electrical panel.
6. The basic Mercedes charger is 120V only and does not appear to be upgradeable to 240V. If you want to portable 240V charger (120V is almost worthless) I would buy an aftermarket charger. There are plenty of good options on Amazon that will be much cheaper than a Mercedes branded charger.
TeslaTap
https://ev-lectron.com/products/lect...waAhvLEALw_wcB
controlling the amperage is via a dial on the back panel and based on the position is whether you want 48, 49, 32, etc
I like the display, the power options and overall good value
we have Tesla wall connectors at both our homes and have used these for charging an ID.4
I prefer this over TeslaTap as it’s UL approved.
can be found on Amazon as well for same price.
https://ev-lectron.com/products/lect...nnectors-black
https://evchargeplus.com/ev-specific...-benz-eqs-suv/
I'm interested in where you folks have read max charging is 9.6kwh
EDIT: The order guide is available in this forum:https://mbworld.org/forums/eqs-suv/8...der-guide.html
the order guide states 9.6kW AC charging
looking forward to seeing some real life YouTube videos on range and DC/AC charging
When I use the same charger to on my Tesla Model 3, it charges at 48A, which lines up with the 11.5 kW max capacity of that car's onboard charger.
I just went to City Electric Supply website. They have both versions in stock at $749.
