EQS SUV Forum for Discussion of EQS SUV
Customizing the Dash Screens
Old Jun 4, 2024 | 09:17 AM
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
Is it possible to see the tire pressures on the Classic dash screen? I don’t see how…
I can customize my 2019 G Wagon screen this way, so I’m surprised that this doesn’t seem possible with MBUX?
In between the speed and % power dials, I don’t see the option to see tire pressures…
Old Jun 4, 2024 | 09:37 AM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
There is only one screen that shows tire pressures but I do not use that screen otherwise. I usually just ask Mercedes, “ What are the tire pressures?”
Old Jun 4, 2024 | 09:39 AM
Surge's Avatar
I find that majorly disappointing - how can the latest MBUX interface have LESS customization than the 2018 design UX? I have way more customization options in my 2019 G Wagon dash display.
I don't want to ask Mercedes for the tire pressures - I want to see them on the display at all times.
Old Jun 4, 2024 | 11:52 AM
LastOne's Avatar
EQE350 SUV 4MATIC
You will need to adjust your expectations and operations management. The tire pressure will typically vary by no more than 2 or 3 degrees and the system will warn you about a loss of pressure, so there is very little to worry about. For my showing tire pressure continuously is useless information much like a tack on an ICE vehicle.
Old Jun 4, 2024 | 11:55 AM
Surge's Avatar
Yeah, no, respectfully disagree. If you have a slow leak you will not notice it until the system warns you, which will be when you have lost much more than 2-3 psi. If you identify a slow leak soon, you can address it before it leaves you stranded. I have experienced it first hand if you don't have the display showing all the time, and it will warn you when the tire is flat. That's why I always have the tire pressures displayed on the G and AMG GTC.
In any case, it should be up to the driver to decide, and we should have more flexibility to customize, not less, with each generation.
Old Jun 4, 2024 | 12:30 PM
LastOne's Avatar
EQE350 SUV 4MATIC
I use run-flats so not a concern for me.
