EQS SUV service inteval
Brake fluid should be changed every 2 years.
Typical EQS “Service A” items
- General inspection of brakes, suspension, steering
- Check and top off fluids (washer, coolant, etc.)
- Cabin air filter check or replacement
- Tire rotation and pressure/TPMS check
- Software/telematics updates and diagnostics
Typical EQS “Service B” items
- All Service A checks
- Brake fluid replacement
- More comprehensive underbody and high‑voltage visual checks
- HVAC system checks (blower, filters, odors)
- Additional maintenance items based on time/mileage (e.g., coolant checks)
Unless you have unlimited funds, do the work yourself like the cabin filters, wiper blades, and even brake fluid if you have the tools. I've bought two CPO cars (one BMW and one MB) with undercarriage damage that somehow was not noted on the 'rigorous' CPO process--hint--the CPO process was a multi step process of washing the car and driving it out onto the lot.
The problem I see is that, they rush things as a result to get something done so they can move on to something else, so the quality of the job may not be the best it can be.
However, the oils in an EV are in the reduction gearing and differentials so face a far smaller temperature regime, no combustion product contamination, and do not need additives for cleaning, etc. Thus the oil lasts many years without issue.
The fluid that does need to be changed on a regular basis in an EV is the DOT-4 or DOT-3 brake fluid, which is hydrophilic and will over time absorb moisture from the air. This needs to be checked every two years and replaced if the water content is too high.
If your dealer is claiming the "oil" in an EV needs to be changed every year or 10K miles it is time to find another dealer. Yours is lying to you about the service required for Mercedes EVs.
You are on the EQS thread so I guess that is why we thought you were talking about the EQS when it comes to the services.
For me, plugging in takes about 5 seconds after I park. I don't even need to do that every day; I often skip days when I'm feeling extra lazy, because the battery range is more than what I drive in a week. Although most EV drivers charge nightly, it's because it's easy not because of need. As much as some people perseverate on range, the truth is the average US driver does about 260 miles a week. So for all but the cheapest electric cars, most people don't need to charge more often than once a week.
Early in my consulting career, I drove about 320 miles a day round trip from Clearwater, FL to a client on Sanibel Island, FL. At that time, I had a MB 300SEL 6.3 (108) that I filled twice a day - 26 gallon tank @ 8 mpg. After a few months I added a MB 300d (W123) just for trips to that client. FYI I drove that 300d for 10 years and over 500k trouble free miles. Oil was changed every week and tires every year. The battery was changed once.
** edit ** Gas was about $0.40 per gallon back then before the OPEC oil embargo. My next car will be an EV.
Back when the first Leaf came out with 70 miles of range, it was only suitable for very few people. But after 16 years, modern EVs have perfectly adequate range for the average (95-th percentile) US driver, even without charging at home nightly. For the 5%-ers such as your old consulting job, or the occasional long roadtrips, the problem of charging speed will eventually fade too; BYD is starting to sell EVs that can charge to 80% in 6 minutes.
