Question for those wh have received their EQS
VPC times can vary a lot depending on the individual car. If the car sustained damage during shipping, which regularly occurs, then it'll spend more time at the VPC to restore it to factory conditions. MB says on average it takes 10 to 20 business days to go through the VPC process. That was even the case before the EQS. For reference, my '19 C63S took around 20 days, but I did European Delivery and had sustained some minor damage while driving in Europe, which the VPC repaired. They also filled the holes from the front license plate and restored everything to factory condition, so I guess mine was at the longer end of the process due to all that body work, but gives you an idea. Cars that spend a lot of time at the VPC typically arrived damaged, or need an update or part that wasn't ready yet when it left the factory, except at the beginning of a new model year they are held up until they are officially signed off by the EPA and legal to sell, so if you order early then VPC times can be quite long as you have to wait until they get officially released. Once officially released, the times at the VPC will be a lot shorter for subsequent shipments.
There's also a trucker shortage at the moment that you might have heard about, so while the car could be done at the VPC it might have to wait quite a bit before it is picked up by the next available transport.
VPC times can vary a lot depending on the individual car. If the car sustained damage during shipping, which regularly occurs, then it'll spend more time at the VPC to restore it to factory conditions. MB says on average it takes 10 to 20 days to go through the VPC process. That was even the case for the EQS. For reference, my '19 C63S took around 20 days, but I did European Delivery and had sustained some minor damage while driving in Europe, which the VPC repaired. They also filled the holes from the front license plate and restored everything to factory condition, so I guess mine was at the longer end of the process due to all that body work, but gives you an idea. Cars that spend a lot of time at the VPC typically arrived damaged, or need an update or part that wasn't ready yet when it left the factory, except at the beginning of a new model year they are held up until they are officially signed off by the EPA and legal to sell, so if you order early then VPC times can be quite long as you have to wait until they get officially released. Once officially released, the times at the VPC will be a lot shorter for subsequent shipments.
I also have a BMW IX with a build date of May 13. So will be interesting to see which car arrives first.
