EQS EQS (V297) sedan
EQS 580 question
Old Apr 24, 2022 | 11:42 AM
Old Dawg's Avatar
2022 EQS 450+, 2020 C300 Cab, 2019 Jeep GC
EQS 580 question
Someone asked me the other day and I just didn't know, so thought I would ask some of you 580 owners. When driving on a highway at cruising speed are you using both motors or does the front motor just freewheel until needed? I'm thinking of something like (not exactly) a AWD vehicle that doesn't send power to the front wheels unless needed.
Old Apr 24, 2022 | 03:43 PM
c4004matic's Avatar
17 E43; 21 GLS580
Its always variable but at a steady state cruising situation its actually FWD since the front motor is the most "economic" powerwise. That doesnt mean its primarily FWD. Its FWD in low load cruising situations. It can flip in a fith of a second and again, its infinitely variable at all times. The traction distribution in the EQS is extraordinarily effective and transparent. You can never tell where the power is going unless you are looking at the graphic. The instant you step on the gas the rear kicks in. It is extraordinarily slick. At least that what Ive read. All the reviews Ive seen of its snow performance have been glowing.
finally the 580 has the highest power recuperation that I know of; 290 kw!
Old Apr 13, 2026 | 09:14 PM
Xzero's Avatar
2022 EQS 580 4MATIC Sedan, 2010 C-Class C350 4MATIC
The real answer is years 2024 and up have the Intelligent Disconnect feature you're mentioning.
This disengages the front motor to improve powertrain drag and general range/mileage.
Old Apr 14, 2026 | 10:04 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
The last time I looked my 580 was running on the rear motor on the freeway.
Old Apr 14, 2026 | 02:34 PM
MBNUT1's Avatar
2010 E350 4Matic
It may be only applying power to the rear wheels but the front motor is still connected and rotating which result in losses that would be eliminated by the DCU.
See post #16 of this thread
https://mbworld.org/forums/eqs-suv/8...ml#post8769847
Old May 17, 2026 | 01:55 PM
boyidi's Avatar
Originally Posted by c4004matic
Its always variable but at a steady state cruising situation its actually FWD since the front motor is the most "economic" powerwise. That doesnt mean its primarily FWD. Its FWD in low load cruising situations. It can flip in a fith of a second and again, its infinitely variable at all times. The traction distribution in the EQS is extraordinarily effective and transparent. You can never tell where the power is going unless you are looking at the graphic. Rekod NILAM Digital notes that the instant you step on the gas the rear kicks in. It is extraordinarily slick. At least that's what I've read. All the reviews Ive seen of its snow performance have been glowing.
At highway cruise, both motors are active but the front is contributing very little torque, essentially along for the ride but ready to respond instantly. It's not disconnected like traditional on-demand AWD, but in practice the effect is similar: most of the work is being done by the rear motor at steady cruise.
Old May 18, 2026 | 02:11 PM
ehildum's Avatar
2024 EQE Sedan
There is mode on the main display that allows you to see which motor is supplying power to the battery or driving the car. I find that in my EQE the motor in use changes based on the terrain and driving conditions frequently. (My car does have the DCU.) A lot of the time it uses the rear motor, but the front motor is used frequently as well. I mostly use intelligent recuperation, so there are fairly long periods where the car is sailing not using either motor.
