EQS SUV vs EQE SUV (which has heat pump)
- The battery is larger in the EQS than the EQE SUV, so this fact would probably "offset" some of the range difference between the two vehicles due to lack of heat pump
- If you're in a climate that is close to 70 degrees F much of the time, you may not really suffer any "penalty" for not having a heat pump on the EQS. If you are in a cold climate, you will suffer. Wild guess: Maybe 5-15% range from the various postings I've read.
- If you're getting a 4matic, you should know that the EQE SUV's can actually de-couple the front motor when not needed during highway driving. On the EQE's this is purported to lead to up to 5% range enhancement. It is my understanding that the 2022 and 2023(?) EQS's do not have this capability.
- If you're contemplating buying a maintenance package, take a look at the cost of it for the EQE vs. the EQS. Where I am, the EQS maintenance plan is significantly more expensive. Not surprising, I guess.
- Ditto above for extended warranty
- Ditto above for insurance.
I had intended to purchase an EQE, but since I could not find any info on the cargo area dimensions I was skeptical about how well my wife's rollator walker or wheelchair would fit behind the rear seats. When the EQS came out and the $7500 tax credit was available through 31-Dec-2022 I decided to get the EQS SUV instead. I definitely make use of the extra space in the EQS and the rear steering makes the car seem smaller than it is. The one thing I would have preferred in the EQE is the lower height which would probably make entry and exit easier for my wife.
This will show you whether or not the car is using power, regenerating energy, or coasting/sailing. It also shows you where power is being sent.
If you have the front motor disconnect, you’ll notice while you’re driving that sometimes power is sent to just the front motor, sometimes power is sent to just the rear motor, and sometimes it’s sent to both. Sometimes just one of them will regenerate, sometimes both do.
Real Range Estimationbetween 215 - 425 mi
City - Cold Weather * 300 miHighway - Cold Weather * 215 mi
Combined - Cold Weather * 255 mi
City - Mild Weather * 425 mi
Highway - Mild Weather * 270 mi
Combined - Mild Weather * 335 mi
-Sen
-Sen
Similar to coasting your ICE car in high gear... no gas/energy is being sent to the motor but it is still connected. Coasting in high gear is not the same as coasting in neutral... which is analogous to Your current 2023 EQS and a 2024 EQS with a DCU.
