EQS 580 jerks a few seconds after start driving
Im pretty sure its a "hand off" hesitation. At that speed 20-25 (it always happens at this speed!) The low speed collision system transitions to a different level. What is happening is that when it does so, there is a partial activation. It cuts the power for an instant without applying the brakes. It almost feels like a strong shift. Its a software booboo. The same thing also happens occasionally on the highway when passing a big box truck a little too close (not). It's sensing a phantom. It's not an overt safety concern, but MB is well avised to look into it. It could also be a radar sensor issue. Not the little ones we see on the bumpers, the bigger ones behind the bumpers.
same here... i learned to be "gentle" with acceleration for the first 30 seconds after every cold start. it's annoying. brought it to dealer the SA said maybe a slow response to release rear brake caliper? but he didn't do anything to it as there was no "fault code"
Good if owners find ways to avoid the issue but it would still be interesting to know the real source of that behaviour, specifically when it seems to concern EQS only, or is it all MB EVs? Nothing like that on hybrids or ICE cars even if the brakes should very similar.
Mine, too, has almost disappeared....only happens rarely now.
#33
Jerking and malfunction light
Hi all,
I have this very annoying thing on my 600 mile old EQS 580 - after I get in the car and start driving, may be for the first 20 sec - the car jerks once, similar to what you would get from a very bad transmission on a gas car - and after that everything is fine. I noticed that this happens only after the car has been parked for a white - it doesn't happen when I turn it off and turn it back on right away. I'm waiting for my appointment for the "Open socket flap" issue and I will definitely mention this one, but I'm wondering if anyone else had this problem. It is especially bad when I step on it a bit harder - the jolt it really violent.
#34
Mine still does it in a blue moon. I still think its a sensor or software snafu when the car transitions from slow speed sensors (the ones on the bumpers) to high speed sensors (the larger ones underneath the corners). In effect its kind of a version of (ghosting) whats happening is that the power is cut for an instant. In my case its a small rare annoyance. Aside from a couple of Mbux failures to activate episodes the first few months, the car has been utterly free of problems. I expected hiccups on a completely new model with an entirely new drivetrain. In fact, in my book, it's been better than I had hoped for for such a revolutionary vehicle from a company that, quite frankly, is not known for its reliability. The car drives, rides and performs spectacularly AND has superb EV abilities. Its not perfect but boy what a machine.
The following 2 users liked this post by c4004matic:
Diesel Benz (05-10-2023),
ScottC2 (05-10-2023)
Sir Lennox (06-03-2023)
#38
#40
Received 2,512 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
#42
#43
EQS 580 2022 Date of production 12/21 . Recent update to latest MBUX UI NTG 3.xx , and dealer updated drivers assistance software as well. Jerking from cold starts has resolved (24 to 25 mph). If you have a 2023 model and have this issue, I don’t know what to say.
#44
Thank you for this information, will need to look into the update but what was the cause though?
#45
This is from my service log for this issue previously before the new drivers assistance update resolved the issue :
“Test drove vehicle several times for jerking motion intermittently at 26-27 MPH under light throttle. We were unable to duplicate the condition at this time. While driving the vehicle, it was noted that the front E-machine engages at 26-27 MPH under light throttle, which is the speed that the client had reported the condition happening. Xentry tips case # 245289861 was opened for any assistance with this condition. After thorough investigation by Mercedes Bens technical, it was found that there is a software in development to repair this condition. There is no ETA on when the software will become available. When the software becomes available, an update will be sent out so the client can be notified.”
#46
dealer service advisor maybe able to look up the xentry tips case # and see if there have been updates to the case from MBUSA .
#47
Volkswagen Passat Alltrack 2000
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
The problem is that the software does not work correctly, which leads to such a problem. Try to go to some car service for a software check. From your area like this service is : https://autoshina.md/regulirovka-podshipnika-stupicy/
#48
#50
