EQS EQS (V297) sedan
"Idle" - bad for battery?
Old Jan 6, 2023 | 12:27 AM
JZK26's Avatar
2023 AMG EQS
Say I'm sitting in the car for 45 min to 1 hour (waiting for kids to finish class). Ignition is in (the car says "ready" in green), AC on, car is in park. Battery drops very slowly, if at all. Maybe 1-2 percent over the whole hour. Question: does sitting often like this, I.e. using the battery without spinning the wheels (no regen, among other things) - is this causing damage? Long term maybe? I doubt it but was wondering if anyone had any insight.
Old Jan 6, 2023 | 07:10 AM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
Just a hunch but I doubt the batteries would be hurt in any way. I thought that if there was not any movement the EQS would power down on its own after 15 minutes or so. Mine gives me a warning on the dash board.
Old Jan 6, 2023 | 07:54 AM
Diesel Benz's Avatar
Since battery power consumption is low, also wear on the battery (and the high voltage system) is minor. The HVAC system wear would be more or less the same as if you were driving (don't think you were concerned about HVAC).
Spinning wheels would mean more power consumption and more wear (but that is what the car is built for). Recuperation is not healthier than driving the car without recuperation or keeping the car ready when stationary. Recuperation charges the battery and causes battery wear just like charging the car from a charger. Not that much but the sign is negative, not positive. Recuperation is healthier than using normal brakes but this is not relevant when stationary. Of course recuperation is healthy for the wallet.
Old Jan 8, 2023 | 09:20 PM
perlfather's Avatar
911
As for using the battery, how is this different than using a computer, iPad or Apple/Samsung watch, etc. running on its battery? Keep the battery between 20% and 80%, do not worry, and enjoy!
Old Jan 9, 2023 | 12:46 PM
c4004matic's Avatar
17 E43; 21 GLS580
No problem at all. In an EV idling is not a thing. On the other hand if in park the car will shut itself down after 15 minutes or so to preserve the 12V battery. If you want the car to stay on you have to leave it in neutral and manually use the parking brake. Some people refer to that as "camping mode"​​​​​​​in that setting, the battery will run the vehicle's accesories for a very long time.
Old Jan 9, 2023 | 08:52 PM
LasVegas_89135's Avatar
2023 Mercedes ESQ SUV 580 ● 2021 Volvo XC40 Recharge
My EQS is still on order. But my experience with my Tesla Model S and my wife's Volvo XC40 Recharge is that charging up to 90% regularly is not an issue with those 2 cars. Is the EQS different and the manufacturer recommends charging to up to 80%?
Old Jan 9, 2023 | 09:51 PM
perlfather's Avatar
911
I do not think the EQS battery is very different from the others, although the exact anode construction is critical. Different manufacturers have different amounts of "safety" at the top and bottom. It is well known that charging to the top and bottom degrades batteries faster than when charging and discharging them part of the way. I do not know the exact tradeoffs (for example - charging 100 times to 100% vs. charging 100% to 90% results in a decrease of available charge by x%. ) My impression is that 1.) the car manufacturers have not shared this type of data with the consumers and 2.) we are all being very conservative. Since Teslas have been around for the longest, there is probably a lot of data available on battery longevity and degradation from Tesla owners. Four years ago, I spoke to a knowledgeable Audi designer/engineer who thought we'd all replace batteries after ten years instead of rebuilding engines.
Old Jan 10, 2023 | 07:34 PM
perlfather, Thanks for the reply.
The reason for my question is that I've noticed many posts here talking about charging up to 80% and I was wondering if that is what MB recommends. My experience with Tesla is that they recommend up to 90%.
Old Jan 10, 2023 | 08:16 PM
Newbyloub's Avatar
2018 S560; 2022 EQS450+
Asked, answered, and commented upon many, ,many times. MB suggests a maximum general recharge of 80%.
Old Jan 10, 2023 | 08:17 PM
c4004matic's Avatar
17 E43; 21 GLS580
Mercedes recommends 80 I generally do so in summer. In winter Im doing 90 to compensate for the shorter range.
Old Jan 10, 2023 | 08:52 PM
Newbyloub's Avatar
I'm sure this makes sense for a number of people; it just doesn't help me any. As my only accessible charger is in my garage, recharging every 3 weeks instead of every 4 doesn't help me.
