EQS EQS (V297) sedan
Eqs wheel & tire switchout 450+ sedan
Old Jul 1, 2023 | 08:07 AM
atxbenzy's Avatar
Eqs 450+
hi all,
mine came with 22’s from the factory and pirelli’s. May be time to switch tires soon and considering switching to 20’s for better range and maybe a more cushy ride. i can coax 400 miles out of her now with careful driving. I see some reasonably priced oem 20” wheel and tire sets for sale online. My nube question: is switching out the tires and wheels a plug and play type deal or more complicated. Would you only trust a benz dealership to do it or would a place like firestone suffice? What is a ballpark cost of the installation? Anyone know a good installer in austin?
thanks
Old Jul 1, 2023 | 11:48 AM
LAZARU5's Avatar
2025 E53 Hybrid
Originally Posted by atxbenzy
hi all,
thanks
I am in the process of swapping out the 21" wheels with 275/45-R21 tires on my EQS 450 4Matic SUV for 20" wheels with 265/50-R20 tires. You might find the calculator at this website helpful to determine the amount of speedometer/odometer error you will get with the 20" tires.
https://willtheyfit.com/
I am not expecting much difference in mileage with the smaller diameter tires. Even though the 20" tires are 10mm narrower than the 21" tires, the contact patch happens to be 8.9" wide on both of the tires. I did find other 275/45-R21 tires with a wider 9.3" contact patch, and those would probably reduce the mileage compared to my current 21" tires.
The 21" Goodyear tires on my SUV have a tread wear rating of 500 compared to an 800 rating for the 20" Pirelli tires. In my case I will get a maximum of 24K miles out of the 21" tires if I run them until the wear bars are reached. I am hoping to get twice that mileage from the 20" tires if I rotate them frequently (every 4000 miles). This should reduce the cost of tires from about 10 cents per mile to 2.5 cents per mile. I only rotated the 21" tires at 6000 miles and 15000 miles and the difference in wear from one tire to the next is significant.
The lug bolts on the EQS SUV are 65mm long. I would recommend using wheels with a "297" prefix in the part number for your EQS sedan. It took awhile for me to find 20" wheels with a "296" prefix (EQS SUV chassis number). Using wheels with a prefix that matches your chassis number guarantees that the wheel offset is correct and that your existing lug bolts will work.
Old Jul 13, 2023 | 12:43 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
I was thinking of doing 22" for looks now since the wheels I got with the car cannot be painted/coated since they have the areo discs on them are glued. Seems stupid from Merecdes. Other option is to run 20" GLE53 wheels with a fatter tire for more comfort vs looks!
Old Jul 14, 2023 | 06:18 AM
stealth.pilot's Avatar
2022 Mercedes EQS 580
I can tell you that the 21” Goodyear non run flat summer tire has much better range than the Pirelli all seaso run flat. I have had both on 2 different EQS580s.
I’m curious how much of that range loss is all season vs run flat.
Old Jul 14, 2023 | 09:13 AM
djrabbi's Avatar
Agree. I switched to 21" continental from 20" goodyear. I lost 40miles at leat. Wheels are lighter than OEM but I guess tires aren't "EV" rated
Old Jul 14, 2023 | 11:37 AM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
I have read from reports of folks needing new tires that if you do not replace with tires designed for EV’s you will suffer some mileage reduction per charge.
Old Jul 14, 2023 | 12:50 PM
djrabbi's Avatar
What is the range difference between both? I am thinking going with the pirelli verde which is a "green" tire.
