Active Steering without Cruise Control
Is it possible to activate Active Steering independently of Adaptive Cruise Control so that I can control acceleration and braking while allowing the car to assist with steering?
The following 2 users liked this post by Crito:
BenjaminKohl (09-06-2023),
noobified (09-06-2023)
Active Steering Assist is tied to Active Distance Assist DISTRONIC, and the symbol will been green when active. But even when DISTRONIC is off it seems to be working for me as the car does seem to follow lane markings. I do not think this activity is Active Lane Keeping Assist as that function alerts you of drift by vibrating the steering wheel and actions to guide the car back.
I am still leaning and assessing so could be mistaken.
Received 2,688 Likes
2020 S560 4Matic
No, this is possible in Hyundai/Kia/Genesis products and I really like it, but not possible with Distronic.
You have to turn on the cruise system but you don't have to set a speed, the active steering in mine seems to work either way as long as you have the cruise system enabled and car can detect lanes or the car in front.
Received 3,842 Likes
2019 C63CS
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/381x104/screenshot_2023_09_06_104001_6a95e692dd029746519b0c018e12c54bb2491974.jpg)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/783x532/screenshot_2023_09_06_104112_9282736f46f1e9672a99cbf4d4563bbfb781b097.jpg)
I will have to try again, I wonder if I had a speed limit set (ie distronic is active) but I was also accelerating manually passing that limit. I remember active steering working when I was pushing the gas pedal but can't say for sure without trying it again now.
2019 C63CS
Yes, as far as I remember if you override DISTRONIC with the throttle, Active Steering Assist stays active, even though DISTRONIC temporarily suspends. So, I suppose one possible workaround for OP would be to set a really low speed for DISTRONIC and then just override it with the throttle and pretend DISTRONIC isn't even active. Just remember that when coasting to a stop it will suddenly kick in again.
2020 S560 4Matic
Active steering works In my 24 GLE53 w/o cruise as long as I select that option in system. And it is very “gentle”. With CC it is more robust.
2019 C63CS
2020 S560 4Matic
As was said above, you are describing lane keep /active steering assist not lane centering which is only available when Distronic is set. You will have a green steering wheel on the display when lane centering with distronic is active, and you cannot have that without distronic set.
The reason I asked is because I rented a Kia and, as several have pointed out, it had active steering enabled while I controlled throttle and brakes. It's a great feature.
2019 C63CS
Yes, you can set the speed of DISTRONIC to something low and override it with the throttle temporarily without deactivating it. However, stepping on the brake peddle will. I guess setting the car to Strong Regeneration might help with not having to step on the brake peddle.
Sounds like you are asking for a more intrusive Lane Keeping Assist. The MB Lane Keeping Assist will only intervene once you get close to the lane markers and will quite abruptly yank the car back into its lane. Kia's approach is essentially softer. Audi's LKA is similar in that it also proactively steers the car back into its lane. I quite detest that kind of LKA as it constantly messes with the steering when I'm driving. I've turned off LKA actually as when I'm driving I don't need an assist to stay in my lane. I've also had an Audi rental in Europe last summer and LKA was super annoying as it got confused at road forks and road constructions, fighting me when I was trying to follow the correct lane. It was more dangerous than anything. I guess if I want the car to do some of the driving, then I do a controlled handover to DISTRONIC and active steering, but if I'm operating the peddles, then I'm operating the whole car and I don't want a computer to fight my steering input.
As I understand it what Kia has is Lane Keep Assist with different alert levels. In its highest setting it provides frequent feedback to help correct steering and prevent lane drift. That's not the same as MB's Active Steering Assist. LKA only takes the lane markers into consideration. MB's Active Steering Assist also takes other cars into consideration and can actually steer the car outside of its lane if necessary for example if the traffic has to snake around an accident or something.
2020 S560 4Matic
Issue is as soon as you take your foot off the gas it will slam on the brakes to bring it down to the set speed, and it will display a n override message every time you depress the accelerator.
Best to just accept that the feature doesn't work that way
