EQS EQS (V297) sedan
Request: Tire pressure placard for 255/45R20 - sedan
Old Feb 16, 2024 | 04:12 AM
grandcurmudgeon's Avatar
EQS 450v4
Question Request: Tire pressure placard for 255/45R20 - sedan
Could someone with a 450v4 sedan with 255/45R20 tires post a photo (or the data) of the tire pressure placards? I can't get consistent info googling around. Most of the data is for SUV, which has different sized tires.
Thanks!
Old Feb 16, 2024 | 06:11 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
Thanks!
I don't have 20 inch tires, but your info should be in your owner's manual, also.
Old Feb 16, 2024 | 02:31 PM
Mort's Avatar
The tire pressure table should be on the B-pillar on the driver's side of the car.
Old Feb 29, 2024 | 01:11 AM
EQS 450v4
For anyone who finds this in a search, the correct answer is:
Normal load: Front 41, Rear 41
Max load: Front 41, Rear 42
The owners manuals don't even mention tire pressures because there are myriad options. The stickers on the car will obviously only apply to the wheels that came with the car. They're of no use if you change wheels, other than to derive the correct values mathematically.
Old Feb 29, 2024 | 01:16 PM
LAZARU5's Avatar
2025 E53 Hybrid
....The stickers on the car will obviously only apply to the wheels that came with the car. They're of no use if you change wheels, other than to derive the correct values mathematically.
Not necessarily....
My EQS SUV has two tire pressure labels. One only shows the size for the factory equipped tire size, 275/45-R21. The second label also includes the optional 265/50-R20 tire size. Neither label includes the tire sizes for the SUVs with staggered wheels.
