EQS EQS (V297) sedan
Service reset not working
Old Jul 13, 2024 | 01:54 PM
TommyV72's Avatar
2022 EQS AMG
Please help! So I am actually a technician, all brands not specifically MB only. This is my vehicle 2022 EQS AMG, I can not get the service reminder (assyst plus) to reset. Actually I can't even get to that menu. Heres the deal:
I get in car, close doors.
Start button one time
Display on trip of course
Standard or classic display
Press and hold home for 10 seconds
Then I press the OK button this is supposed to be 10 seconds also but this doesn't work. I get a stupid pop up to "set a shortcut"
Have tried using my scan tool as well however this doesn't work on EQ models.
Please help, what am I doing wrong????
Old Jul 13, 2024 | 08:51 PM
LAZARU5's Avatar
2025 E53 Hybrid
Try to shorten the time between releasing the Home button and pressing the OK button. Try using both hands. I have accessed the workshop menu several times, but, it was after many failed attempts.
Old Jul 14, 2024 | 01:34 AM
TommyV72's Avatar
2022 EQS AMG
Ok, I will try this in the morning, however I still think the problem is this "shortcut" message.
I'll report back....
Old Jul 14, 2024 | 07:07 AM
W205C43PFL's Avatar
See if these help
https://mbworld.org/forums/w213-amg/...ml#post8990737
https://mbworld.org/forums/glc-class...ml#post8990140
Old Jul 14, 2024 | 05:08 PM
TommyV72's Avatar
2022 EQS AMG
Ok so update:
As per LAZARU5 I tried again using 2 fingers, the first holding the home button then immediately with second hitting the ok button. I was using my thumb on home then sliding it quickly to ok. Obviously this was not fast enough! LAZARU5 I did it your way and it worked straight away! Blows my mind it needs to happen in such a short amount of time. When I did it this way also the "shortcut" message did NOT pop up, so I would use that as a determination if you are doing it correctly or not.
Thank you LAZARU5 !!!!!
Old Jul 14, 2024 | 06:50 PM
LAZARU5's Avatar
2025 E53 Hybrid
Ok so update:
....Thank you LAZARU5 !!!!!
Were you doing the second 20000 mile service? If so did you do anything besides change filters, replace wiper blades, and inspect pads and rotors? I decided to skip the brake fluid flush at 40K miles since it was only 10 months since the dealer performed the complimentary 20K mile service.
Old Jul 14, 2024 | 08:21 PM
TommyV72's Avatar
2022 EQS AMG
Yes I did the complete 20K, the filters from the dealer are very expensive for filters! All pretty basic stuff.
Old Jul 14, 2024 | 09:52 PM
LAZARU5's Avatar
2025 E53 Hybrid
I ordered all the parts online from MidAtlanticMercedes.com for about 25% off of MSRP. I replaced the large pre-filter under the hood but decided to run the HEPA filter until 60K miles.
