EQS EQS (V297) sedan
Door handles on 2022 EQS 450+
Old Jul 14, 2024 | 09:13 PM
mercRT's Avatar
When I come close to the car and usually all the handles will pop out. But sometimes when I come close to the car, all the handles pop out but except the front right one. Does anyone have the same problems? Any advice to fix this or is this a function?
Old Jul 15, 2024 | 08:22 AM
W205C43PFL's Avatar
Originally Posted by mercRT
When I come close to the car and usually all the handles will pop out. But sometimes when I come close to the car, all the handles pop out but except the front right one. Does anyone have the same problems? Any advice to fix this or is this a function?https://cimg6.ibsrv.net/gimg/www.mbw...3b27f7532.jpeg
Sounds like a software issue if the hardware itself is working properly in other times.
Old Jul 15, 2024 | 09:20 AM
LAZARU5's Avatar
2025 E53 Hybrid
Since the failure is intermittent I am more inclined to think it's a mechanical issue. A rear door handle on my car failed. It would pop in and out and would work to open the door. But the car could not be locked or unlocked using that door handle. The fix was a new handle which would have cost $500 with installation if not under warranty.
Old Jul 15, 2024 | 04:35 PM
mercRT's Avatar
does it pop out when you come close to the car?
Old Jul 15, 2024 | 05:04 PM
LAZARU5's Avatar
2025 E53 Hybrid
It’s fixed now. But at the time, it did pop out when approaching the car. However it would not open when swiping or lock when pressing the recessed area.
Old Jul 16, 2024 | 04:35 PM
jcapotos's Avatar
2025 Porsche Cayenne S Hybrid + 2023 EQS 580 SUV
I had a similar issue on the passenger rear door handle. It started to make noises and a thumping sound when finally opening. It was fixed under warrantee. They had to replace the bearing bracket and frame.
A CUSTOMER STATES THE PASSENGER SIDE REAR DOR HANDLE DOES NOT COME OUT. PREVIOUSLY IT WOUL MAKE A NOISE WHEN IT MOVED. NOW ITS NOT COMING OUT AT ALL.
CAUSE:
80N0GD67
726420 REMOVE/INSTALL
INNER
DOOR TRIMOF
REAR DOOR
85 W08
1 099-760-30-05 BEARING BRACKET
1 099-760-54-03 ASSEMBLY FRAME
725856 REMOVE/ INSTALL DOOR MODULE OF . . . . . REAR DOOR (INNER DOOR TRIM REMOVED)
8 5 W08
727281 REPLACE BEARING BRACKET OF
. . . REAR DOOR (DOOR MODULE REMOVED)
85 W08
541011 PERFORM QUICK TEST 8 5 W0 8
P A R T S :
0 . 0 0 L A B O R :
0 . 0 0
TOTAL
LINE
:A 5427 rear right passenger door handle makes a grinding noise when actuated and dose not come out removed door trim and removed window
regulator removed door handle bearingbracket seems ok but believe internally its damaged replaced plastic ring aligner and replaced
bearing bracket and aligned door handle reinstalled all in reverse order and performed initialization and update of door handles all four door handles are working as design *美*文****水**兴*大买**大买文买***
