EV Home charging options
To make sure everything was up to code, I just had Wolf River Electric swing by to wire up a universal station and it's been working perfectly. It's honestly a lifesaver having a reliable home charge instead of constantly hunting for public stalls.
For EVSE, YouTube channel State of Charge has a lot of reviews and comparisons. I settled on a refurb Grizzl-E Classic 40a and have been very happy with it.
1. Wrong breaker type (requires GFCI breaker for outlets in garage - this was a somewhat recent change to NEC, but they should have known)
2. Wrong outlet type, they tried to use a standard, light duty outlet instead of one designed for continuous load.
The initial design of the system and the person handling the building permit application was a licensed contractor who knew what he was doing, but the people that showed up to do the install were non-licensed employees not familiar with code and the particulars of a continuous duty circuit. I forced them to call the boss about the two issues above, and in both cases the boss backed me up, requiring them to go back to the electrical supply house and buy the right parts.
If you had a plug overheat, then the most likely cause was a $10 standard grade outlet, not an EV rated continuous duty outlet at $40 - $100. I made them install a Leviton EV outlet (https://www.homedepot.com/p/50-Amp-1...-R10-1450R-0B0). A standard grade outlet is good for a dryer, oven, or stove that do not draw power continuously, but will overheat and melt over several hours of high current draw when charging an EV. The vast majority of electrical hardware commonly available is designed for the intermittent use that is the norm for household electrical circuits and if you look at those Youtube videos and reports, you will see that they used a standard NEMA outlet, not one designed for continuous duty.
Until EV charging came along, there has been no need for continuous duty capable components in households, and there isn't any standard marking for components that can take continuous duty. Leviton's EV mark on this outlet is an attempt to distinguish that this outlet is capable of charging an EV. Don't assume that those contractors or installers know the particulars of an EV charging circuit either - most of them don't know, or want to cut their costs, so will install an under capacity outlet if they can get away with it.
But I agree, apparently that isn't enough for the cheaply made outlets.
I opted for a plug-in because the car comes with a Mercedes-Benz Mobile Flex Charging Cable so there is no need to buy a wallbox charger.
1. Cheap outlet components that cannot take a continuous load, this is the most common failure I see on the internet.
2. Incorrectly configured hardwired chargers where the charger is set to draw more current than the circuit supports (given the 80% rule and the installed wiring/breaker).
And if you want to be really safe, put a wifi data logger (temperature sensor) at the connection/outlet. During peak charging, the surround box will get up to about 95-97 degrees F max. I know because I have one, and looking at the data logger, I know how long it takes to charge my car bases on the rise and fall of the temperature. Set an alert on the temperature sensor app to alert if it gets to 100. That's probably has safe as you can get without standing there and watching it.
https://ev-lectron.com/products/lect...nnectors-black
I use one at hotels where they still have the older Tesla Destination Chargers.
From the documentation I see, there are temperature and arc protections but not anything that would prevent accidentally charging in the wrong mode. When used with a vehicle with a NACS port, the car will be informed of what charging voltage and mode is used, allowing the car to configure itself for AC or DC charging from the shared pins. That isn't needed in a car with CCS as the AC and DC connections are different, leaving you potentially vulnerable if you use the wrong adaptor for the charge type you are doing.
