EQS EQS (V297) sedan
MB joins Tesla’s Supercharging Network
Old Feb 21, 2025 | 01:34 PM
  #101
c4004matic's Avatar
17 E43; 21 GLS580
Finally! Used my previously purchased lectron adapter. Works like a charm through the Tesla app.
Old Feb 21, 2025 | 01:40 PM
  #102
c4004matic's Avatar
17 E43; 21 GLS580
It also shows up on the MB App. I donxt know if the MBUX system will now guide to them though....I activated the routing function after I was alreay charging...
Old Feb 21, 2025 | 02:24 PM
  #103
c4004matic's Avatar
17 E43; 21 GLS580
It shows on the car's MBUX andvwill navigate to them too! Woohoo after 3 years no more range anxiety or complicated route planning EVER AGAIN. 🥳🥳🥳🥳
Old Feb 21, 2025 | 02:55 PM
  #104
c4004matic's Avatar
17 E43; 21 GLS580
Happier than engorged tick🤣🤣🤣🤣🤣
Old Feb 21, 2025 | 09:17 PM
  #105
enj's Avatar
enj
MB S450 2018 4Matic; MB EQS SUV 450
Nice! Congrats.
I tried it at Tesla with my Lectron adaptor yesterday, it did not work, tried a few times with both Apps. Both Apps (Tesla and MB Me) showed error.
These could be a few reasons, will try a different location next time.
Old Feb 21, 2025 | 09:29 PM
  #106
LAZARU5's Avatar
2025 E53 Hybrid
Originally Posted by enj
Nice! Congrats.
Did you turn off PnC in the MB app?
Old Feb 22, 2025 | 11:52 AM
  #107
Decaffe's Avatar
Eqs 580
DoesDid you turn off PnC in the MB app?
Does
this apply if you are using the Tesla App? We bought a Lectron adapter last May. Installed the Mercedes over the air software that was sent to my husband's phone.
Went to local Tesla charging station and tried to charge using Tesla app. When he plugged in, he got flashing lights on the Mercedes plug in socket area and an "authentication error or try another charger" error on Mercedes screen in the car.
He is not positive he did all of the tasks with the Tesla App (select the individually numbered charger) before physically plugging in the charger (I should never have let him go try it without supervision. LOL!)
Old Feb 22, 2025 | 12:10 PM
  #108
LAZARU5's Avatar
2025 E53 Hybrid
Does
I believe there is an issue with the authentication when PnC is enabled. So in a sense PnC competes with the Tesla app to initiate the charge. If PnC is deactivated in the MB app then you can start charging from the Tesla app. Don’t forget to select start charging before removing the NACS plug from the charger pedestal. Eventually MB will get PnC working at superchargers, but you will still not want to use it if you are a Tesla subscriber getting the reduced pricing per kW.
Old Feb 22, 2025 | 06:03 PM
  #109
whoster's Avatar
EQE SUV 350+
grabbed it at my local dealership in the LA metro area. It felt like the two parts folks thought about tacking on some markup but they went with $185.
Old Feb 22, 2025 | 06:49 PM
  #110
c4004matic's Avatar
17 E43; 21 GLS580
Nice! Congrats.
Remember, only Tesla v3 and above work. If you use the plug share app check if that particular station is labeled as open to non tesla. When I plugged in I used the tesla app to begin charging. Once I started to charge the MB app started asking if I had an MB charger and offered to sell me one. Once I indicated I had an approved charger everything was good to go and the superchargers showed up in the app and MBUX system. Pretty slick.
Old Feb 23, 2025 | 11:42 AM
  #111
enj's Avatar
enj
Thanks for all your suggestions.
I tried today at a different location, it worked for my 450+ with a Tesla App.
I haven't checked this to see if it works with my 450 SUV as yet. Both vehicles' PnC have been turned on in the Mercedes Me app. Not sure why it did not work as expected.
I will try this on the SUV sometime today and report back.
Old Feb 24, 2025 | 09:23 AM
  #112
enj's Avatar
enj
Tesla supercharge worked for both my 450+ and 450 SUV.
It seemed pretty straightforward.
Old Feb 24, 2025 | 09:53 PM
  #113
Knick Fan's Avatar
2023 EQS 450+, 2011 E350 Coupe
Quick note on my experience with Tesla Supercharger.
1. Parking was pretty simple at the location near me. Cord is short but as long as I back up it's pretty easy to reach.
2. MBUX sees the station but the numbering system was off . Vehicle read 1-8 but the stations were labeled 1a,-d,2a,-d so I had to count to reach the intended station I was using. The app sees the charge station numbers as they are.
3. I used the app to pay as it read the stations id correctly. Worked after the third time as it was very temperamental with the order in which it was done.
4. Identify station ID in app and then hit charge...afterwhich I plugged in charger to adapter and then to EQS.
5. Pretty seamless...
Old Feb 24, 2025 | 10:17 PM
  #114
c4004matic's Avatar
17 E43; 21 GLS580
As far as I know, you have to do the transaction through the Tesla app.
Old Feb 24, 2025 | 10:53 PM
  #115
Knick Fan's Avatar
Not true. Mercedes me app works just fine. The charge goes thru ChargePoint when using the Mercedes Me app. I received my receipt right after the charge from them.
Also from the mbusa.com site...
How do I charge my all-electric Mercedes-Benz using a Supercharger?
The Tesla Supercharger network is integrated into the Mercedes me Charge network, so ensure Mercedes me Charge service is active in the Mercedes-Benz app (Manage Digital Extras > Charging > Mercedes me Charge toggle switched to “Activated”). Next, confirm you have the adapter in the Mercedes-Benz app by toggling on the "NACS Adapter" under Charging Status & Settings. This will allow you to locate and route to Supercharger stations. At the station, you can start a charging session through your vehicle’s display or the Mercedes-Benz app. Connect the adapter to the cable, then insert the adapter into your vehicle and the session will begin momentarily. Please be aware that Tesla policy prohibits the use of third-party adapters that are not sold or distributed by an automaker.
Old Feb 24, 2025 | 11:07 PM
  #116
c4004matic's Avatar
17 E43; 21 GLS580
Excellent! Ill try it next time!
Old Feb 26, 2025 | 03:27 AM
  #117
EQEBlue's Avatar
EQE 350 4matic
Has anyone had success in using the V3+/V4 sites? The ones labeled 325kW?
I've used Tesla supercharger over 50-60 times and these new sites have failed 100% of my attempts, activation via Tesla app or Mercedes app/MBUX failed on handshake.
Locale : California, Oregon and Washington.
MBUX E504.
Old Feb 26, 2025 | 08:43 AM
  #118
babrams's Avatar
EQS 580
I have used both V3 and V4 chargers on my 2023 EQS 580 sedan with both the Lectron and the MB (Lectron) adapters. Only with the Tesla app. No problems at all when following the connection procedure
In the Tesla iPhone app:
1. Select a charger first.
2. Then press Start Charging.
Cabling and connecting
3. Remove the NACS connector/cable from the charger.
4. Connect the Vortex adapter to the NACS connector/cable
5. Plug the entire assembly into the car
6. When charging is completed, press Stop Charging.
