EQS EQS (V297) sedan
The "Exploding Windshield" & The Unimpeachable Warranty Playbook
Old Aug 23, 2025 | 10:21 PM
J_Boxer's Avatar
24 EQS 580 4matic sedan Pinnacle trim w/Exec. rear seating pkg.
The excellent investigative work by several members in the "Small explode sound, strange smell..." thread has provided the necessary evidence to diagnose a clear and verifiable issue affecting some EQS owners.
It starts with a sound—a sharp 'pop' from the dashboard on a cold morning. Then, a strange chemical smell. Later, you find it: a crack, appearing from nowhere at the base of your windshield. It wasn't a rock. So, what's going on?
This is a deep dive into the "exploding windshield" phenomenon that some EQS owners are experiencing, and a definitive playbook for how to handle it. The community here, particularly with the detailed contribution from @FirstEV and the dealer invoice, has successfully diagnosed a clear and verifiable issue.
The culprit is a confirmed failure of a specific heating element at the base of the windshield. But to be precise and to arm yourself for a warranty discussion, it's critical to understand the specific technology at play.
Part 1: The "Heated Windshield" Myth - A Technical Deep Dive
There is a significant and understandable amount of confusion surrounding this feature because Mercedes-Benz uses different technologies across different markets and models.
  • The "True" Heated Windshield (The System We Don't Get): First, let's define what is generally meant by a "true" heated windshield. This is a system where the entire glass pane is actively heated, typically via an invisible silver-oxide film or a mesh of micro-fine wires. Think of this as "radiant floor heating" for your windshield. This technology is primarily available in other markets (like Europe and Canada) and on certain flagship SUVs, often under Option Code 597. It is not available on the EQS Sedan in the US market.
  • The EQS Sedan De-Icing System (The System We Do Get): The system on the US-market EQS Sedan is a composite of targeted heating systems. Here is the breakdown by the official factory option codes:
    • Option Code 875 - Heated Washer System: This is the "hot water faucet" of the system, heating the washer fluid, lines, and nozzles.
    • The Heated Wiper Park Area: This is the "electric blanket" for your wipers, located at the base of the windshield to prevent the blades from freezing to the glass. This feature does not have its own standalone option code; it is an integral component of the Winter Package.
    • Option Code DB0 - Winter Package: This is the bundled package required on an EQS 450 to get the full system. It includes Code 443 - Heated Steering Wheel, Code 872 - Heated Rear Seats, and the aforementioned Heated Wiper Park Area.
  • How the System Activates: It's critical to understand that the Heated Wiper Park and Heated Washer systems are fully automatic. There is no button for the driver to press. They are tied to the outside temperature sensor and activate passively when the car is on and the ambient temperature drops below a certain threshold (typically around 40°F / 4°C).
  • How It All Comes Together (The 2024/2025 Models):
    • For the EQS 450+ and 450 4MATIC: The Winter Package (DB0) is an optional upgrade.
    • For the EQS 580 4MATIC: The components of the Winter Package and the Heated Washer System (875) are standard equipment.
  • The Unimpeachable Summary: The system we get is a composite of the Heated Washer System and the Heated Wiper Park area. It is the failure of the Heated Wiper Park element that is causing the thermal stress fractures.
Part 2: The Playbook for a Successful Warranty Claim
For @RadoMB and @nath_h , and anyone else experiencing this, here is your unimpeachable playbook based on the successful claims documented here:
  1. Document Everything: Take high-resolution photos of the crack's origin point. Note any discoloration or melting, as this is your primary evidence against an "external impact" claim.
  2. Use the Magic Words: When you speak to your service advisor, your complaint is not "my windshield cracked." It is: "I heard a pop and smelled a strange chemical smell, and I have a thermal stress fracture that appears to originate from a failure of the windshield heater element." The dealer invoice confirms the cause is "WINDSHIELD HEATER OVERHEATED".
  3. Demand the Fault Codes: As FirstEV's successful experience proves, the vehicle will likely have stored a fault code related to the heating element shorting out. Insist that the technician pulls the codes, as this is the definitive evidence Mercedes-Benz will need to approve the warranty claim.
  4. Reference Precedent: Politely inform your service advisor that this is a known issue, with multiple documented cases of successful, full-replacement warranty claims on forums like MBWorld.
A Final, Proactive Warning
For all of us who have this de-icing system (standard on the 580, optional on the 450), this thread serves as a critical heads-up. Given that this is a documented component failure, it's wise to be mindful. Periodically inspect the base of your windshield, especially around the wiper park area, for any signs of discoloration, melting, or the start of a stress crack. Catching it early and documenting it, especially while still under the factory warranty, is the best possible defense.
Old Aug 23, 2025 | 11:13 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
A most excellent and informative post.
Awesome thread title.
It reads like they title of a Sir Arthur Conan Doyle mystery.
Old Aug 23, 2025 | 11:45 PM
J_Boxer's Avatar
Thank you for the high praise—it feels entirely appropriate for the subject matter. You've nailed the feeling perfectly; the experience with these complex cars is often less about "ownership" and more about being a modern-day consulting detective.
Though instead of chasing Moriarty, we're hunting phantom error codes. And I can confirm that some of these quirky software bugs require a level of contemplation worthy of a true three-pipe problem.
Old Aug 24, 2025 | 11:12 AM
MBNUT1's Avatar
2010 E350 4Matic
Yeah but what if it fails out of warranty?
Old Aug 24, 2025 | 02:09 PM
J_Boxer's Avatar
The simple answer is, "you pay for it." But the strategic answer is more nuanced. This is precisely where the value proposition of two specific financial tools comes into play:
  1. The Mercedes-Benz Extended Limited Warranty (ELW): For those who choose to own, the ELW is the primary factory-backed tool for mitigating this exact risk. A deep dive on the cost-benefit analysis is a topic for another day, but it is the manufacturer's direct solution to the out-of-warranty problem for major components.
  2. Comprehensive Insurance with Full Glass Coverage: Specifically for this windshield issue, a high-quality insurance policy with a zero-deductible full glass coverage rider is the other key. However, as you've correctly noted elsewhere, insurance typically covers external damage (like a rock chip), not a component failure. This is a critical gray area. A savvy owner must confirm with their provider if their glass coverage explicitly applies to a thermal stress fracture caused by a failed internal heater.
So, while the simple answer is "the owner pays," the more strategic answer is that a savvy owner prepares for this eventuality by either extending the factory warranty or ensuring they have a very specific and comprehensive insurance product. It's all about risk management.
Old Aug 24, 2025 | 02:34 PM
hyperion667's Avatar
2012 CLS63
Be careful Sir! Knowledge is power and "they" don't want you to have too much and be overtly informative
Old Aug 24, 2025 | 04:08 PM
MBNUT1's Avatar
2010 E350 4Matic
Can't speak to later ones but for 2022 EQS 580's DB0 was an optional package
https://www.autotrader.com/cars-for-...e=OH&zip=45201
File Type: pdf
Old Aug 24, 2025 | 04:09 PM
J_Boxer's Avatar
A fair warning! But as they say, the only thing more expensive than education is ignorance.
After all, "power" is only considered dangerous by those who don't have it; in the hands of owners, it's simply called leverage.
Though I suspect you're right—my file in their head office is probably getting thicker by the day.
Old Aug 24, 2025 | 05:22 PM
J_Boxer's Avatar
That is a perfectly accurate point regarding the 2022 launch-year models.
The guide's focus, as stated, is on the 2024/2025 models, as these represent the current standardized packaging and the vehicles that members are actively purchasing new today.
Your data point on the 2022 configuration is a valuable piece of historical information for the community, but it doesn't apply to the specific scope of the guide's primary analysis. Appreciate you adding that clarification for owners of the earlier models.
Old Aug 24, 2025 | 11:27 PM
MBNUT1's Avatar
2010 E350 4Matic
It's relevant to those who might be in the market for a used EQS.
Old Aug 25, 2025 | 12:30 AM
J_Boxer's Avatar
In the spirit of the pedantic precision this discussion now seems to demand, let's be absolutely clear: the warranty playbook outlined in this guide applies to any owner of any model year whose vehicle is equipped with the failing component.
Whether that component was included as part of a standard package on a 2025 model or an optional one on a 2022 model is a distinction without a difference. The strategic advice for handling the warranty claim remains precisely the same.
This thread has now achieved its purpose.
Old Apr 6, 2026 | 12:08 PM
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
Excellent thread. Just to add something slightly off topic: I have the "true" radiant heated windshield on my Canadian model EQS450 SUV, which is a rarely configured option. Not sure why, as for about US400 it's well worth it. Anyway, I had the windshield replaced due to a true stone chip crack (I saw the stone hit the glass on the highway), and the new windshield defrosts incredibly quickly (within 60 seconds all snow and ice is gone). The original windshield was nowhere near as fast, which leads me to believe the heating elements were not working! Not sure if there is a more definitive way of checking, but if you have the radiant "true" heated windshield, it should clear of snow and ice very quickly, within 1-2 minutes.
Old Apr 13, 2026 | 06:52 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
Since this came up again, I thought I'd report my experience with a cracked windshield w/ Winter Package. Took it to MB and showed them the crack at the bottom of the windshield, tucked well under the hood. I told them it was a thermal stress crack from the heated windshield. My SA said yes looks like it, but the service manager said "nah, it was a rock". I said how could a rock hit the windshield three inches under the lip of the hood. He said "you'd be surprised". I was surprised, but surprised because he ignored the obvious and I had no recourse. So, off to my insurance company. Safelite first ordered the SUV glass instead of the sedan glass--apparently in the part coding this can easily be done by mistake, so you all might want to clarify if you are in this position. Then Safelite finds out that there is no aftermarket glass available. At this point, my insurance company freaks out and starts delaying the claim. I heard several different stories from them, the first being that they wanted me to pay the difference between the OEM glass and the aftermarket glass (how they would price this w/o a part available, I do not know). It took around six or eight weeks of nonsense and ultimately me having to file a complaint with the state insurance commission before they finally relented and paid. My glass company was trying hard to get it done, but my insurance company's new 'people light' AI approach made things much worse. The glass company said it was the most expensive windshield they'd ever done at almost $4700. After one glass claim in my first 40 years of driving, I've now had three in three years--what the heck?!?
Edit: The three windshields were on three different vehicles--not all on EQS.
Old Apr 13, 2026 | 07:34 AM
Surge's Avatar
That’s crazy! You’ve had 3 cracks with the EQS in 3 years?! Wow.
I am getting Exoshield windshield film applied to the EQS later this month. I have it on my other two cars. Against rock chips, it protects really well. (I know this is not what this was.)
I do not run windshield replacements through insurance because no matter what they say, I’m sure they raise premiums after a windshield claim. They will attribute it to something else when they increase it.
BTW, I paid about $3k CAD (+ sales tax) for a new windshield for the EQS SUV, including the built in heating, and that’s installed by the dealer.
Old Apr 13, 2026 | 07:50 AM
nath_h's Avatar
To be clear, the three cracks have been spread over three cars. One on my EQS, one on my EQB, and one on my CL. The EQB is a sitting duck due to its vertical angle.
Old Apr 13, 2026 | 08:29 AM
ScottC2's Avatar
2023 EQE SUV 500 4Matic
One has to wonder about MB (or new car?) windshields...
In my 50+ years of driving (Oldsmobile, Buick, Mercury, Chrysler, Volvo) I've never had to replace a windshield. Granted, none of these cars had a heated windshield, but still - is modern car glass being produced in a manner that makes it weaker or more stress-prone these days?
Old Apr 13, 2026 | 08:38 AM
Surge's Avatar
My new at the time 2012 Lexus had a side window explode due to a glass defect. Toyota refused to cover it under warranty, saying it was a rock. How does a rock hit the side door when no one is beside you?
I’ve had 5 Mercedes since, and in 13 years and 100k miles, never had a glass issue except with the EQS; but I saw the rock that hit it, it wasn’t small.
exoshield!
Old Apr 13, 2026 | 09:33 AM
ua549's Avatar
In Florida as long as one has comprehensive insurance coverage, there is no need to contact the insurance company. The State has an 800 number to authorize replacement.
Windshield Replacement in Florida
Insurance Coverage
In Florida, windshield replacement is generally covered by comprehensive insurance policies without requiring a deductible. This means that if you have comprehensive coverage, you can replace your windshield at no cost to you.
Replacement Process
The process for replacing a windshield typically involves the following:
  • Duration: The actual replacement usually takes between 30 minutes to an hour.
  • Safe Drive-Away Time: After replacement, it is recommended to wait about 1 to 2 hours before driving the vehicle to ensure the adhesive has properly cured.
Key Considerations
  • Legal Requirements: Florida law mandates that windshields must be free of damage for safety and visibility. Driving with a damaged windshield can lead to legal penalties.
  • Choosing a Service Provider: You have the right to choose your own service provider for windshield replacement, even if your insurance company suggests a specific one.
When I had a windshield replacement, it was done in my driveway including the sensor and camera recalibration.
Old Apr 13, 2026 | 10:19 AM
MBNUT1's Avatar
2010 E350 4Matic
In my view your insurance company should have gone after Mercedes for the EQS windshield given the lack of evidence that the crack was caused by a rock and (I am asumming here) the proponderance of evidance that the crack originated at the heating element.
Old Apr 13, 2026 | 07:53 PM
ehildum's Avatar
2024 EQE Sedan
It is more a matter of (bad) luck. Sometimes the rock hits just right, other times it just bounces off. In roughly 50 years of driving, I have had to replace windshields three times. The first time, I paid the difference to get an OEM windscreen, the second time there was no third party part so I got an OEM windscreen fully covered by insurance. The last time, the ML was at 260,000 miles so I was okay with a third party windscreen for the last couple of years on that car's life (it died at 300,000). None of those were heated windscreens, just badly placed rocks.
Old Apr 13, 2026 | 10:49 PM
MBNUT1's Avatar
2010 E350 4Matic
So you have had a cracked windshield with zero evidence of an impact in the vicinity of the crack?
Old Apr 14, 2026 | 07:40 AM
nath_h's Avatar
I thought the same thing, and I think the insurance company would have been justified doing so. But, the whole thing was such a mess that I didn't want to throw sand in the gears after so much trouble, or give the insurance company another reason to deny the claim, even retroactively if that is a thing. Plus, I did not feel sorry for them with their awful customer service and their choice to replace people with AI and think all would go fine. Sounds paranoid, but it seems like the new customer service strategy is to make things so difficult and frustrating that the customer will give up. My new LG washing machine--same thing. Just a dreadful loop of AI nonsense and eventually long phone holds going to India, all while listening to hold messages about how valuable customers are. I'm looking at any post sale warranty in a new light these days--is it really deliverable in today's world?
Old Apr 14, 2026 | 07:43 AM
nath_h's Avatar
I live in the middle of one of the fastest growing counties in the country. There is construction everywhere. Lots of construction debris and rocks with so many trucks going in and out of work areas. This likely does not help my windshield situation.
Old Apr 14, 2026 | 07:53 AM
ScottC2's Avatar
I guess that would certainly make a difference.
We have nicely-paved roads and trees here.
Moose and wild boar are the real problem for drivers -- but then we're talking much more than just windshield replacement. Usually the car is considered totaled after such encounters. And driver/passenger survival is not always assured.
Old Apr 14, 2026 | 04:55 PM
ehildum's Avatar
2024 EQE Sedan
yes, car was in the shop indoors when it cracked. Most likely some strain in the windscreen from manufacturing. It was fine in the evening, broken the next morning.
