Changing Recuperation in EQS - Is this right?
Are all of the below statements correct?
Left Paddle, can be pulled briefly to increase recuperation and depending upon the recuperation mode the EQS is currently in:
When in D (Default Normal Recuperation) increases to D- (Strong Recuperation)
When in D + (Coast) increases to D (Normal Recuperation)
When in D Auto (Intelligent Recuperation) increases to D (Normal Recuperation) I am guessing here
When in D - (Strong Recuperation) nothing happens because D - is already strongest
Right Paddle, can be pulled briefly to decrease recuperation and depending upon the recuperation mode the EQS is currently in:
When in D (Default Normal Recuperation) decreases to D + (Coast)
When in D Auto (Intelligent Recuperation) decreases to D+ (Coast)
When in D - (Strong Recuperation) decreases to D (Normal Recuperation)
When in D + (coast) doesn't decrease but rather changes to D Auto (which certainly isn't a decrease)
Other ways to change recuperation via paddles:
Pull and hold the Left or Right Paddle to change to D Auto
Thank you!
My car has four modes:
- Strong Recuperation
- Normal Recuperation
- No Recuperation
- Intelligent Recuperation
Here's how the left and right paddles work for me, based on what recuperation mode the car is in. This logic applies whether the car is in ECO, COMFORT, SPORT, or INDIVIDUAL:
If the car is in Strong Recuperation
- Left Paddle - NO CHANGE
- Right Paddle - changes to Normal Recuperation
If the car is in Normal Recuperation
- Left Paddle - changes to Strong Recuperation
- Right Paddle - changes to No Recuperation
If the car is in No Recuperation
- Left Paddle - changes to Normal Recuperation
- Right Paddle - changes to Intelligent Recuperation
If the car is in Intelligent Recuperation
- Left paddle - changes to NORMAL Recuperation
- Right paddle - changes to NO Recuperation
- No Recuperation
It would not only be a great way to meet unintelligent people, but also people prone to road rage.
All the computer nannies are shut off in my car.
Thank you!
The small errors in your logic are all caused by one single, non-obvious detail in Mercedes' design philosophy. You're trying to fit all four modes into a single, linear progression, but the key is that the system is actually two separate systems that you control with the paddles:
- The "Manual" Recuperation Ladder (D+, D, and D-)
- The "Intelligent" Overlay (D Auto)
This is where your logic on tapping the right paddle from D+ was a bit off. You were trying to jump between the two different systems with a simple tap, but the car is designed to keep them separate. A tap only moves you along the manual ladder. If you're at the top (D+), a right tap does nothing. The "press and hold" is the universal shortcut to engage the separate, intelligent system.
Now, the most interesting part of this thread is the conflicting real-world experiences with Intelligent Recuperation (D Auto) from @Povitica3 and @LastOne . One finds it dangerously abrupt, the other finds it perfectly smooth. Both of those experiences are completely valid.
I can personally attest that the "brake check" feeling is a real phenomenon. It's not a flaw; it's a symptom of a misunderstanding of how the car's various driving systems interact. To get the smooth, seamless experience the engineers intended, you have to understand that you're not just controlling one setting, but a four-layer Deceleration Matrix.
Layer 1: The Foundational AI Temperament (Driving Dynamics) This is the "insider" setting that most owners miss, and it's the true root cause of the abrupt stops. Buried in Settings -> Assistance -> Driving, you'll find a choice between Comfort and Dynamic. This doesn't change the suspension; it changes the personality of the car's AI. Dynamic tells the car to be more reactive and brake later and harder. Comfort tells it to be smooth and progressive. This is the master switch.
Layer 2: The Drive Mode (The "Pedal Personality") This is the DYNAMIC SELECT button. It's not just about acceleration; it sets the temperament for deceleration. Comfort mode is programmed for a smooth regen response when you lift off the accelerator. Sport mode is programmed for a much more aggressive, immediate "bite."
Layer 3: Intelligent Recuperation (The "Brain") This is D Auto. It's the strategic layer, using radar and map data to decide when and how strongly to apply regen.
Layer 4: DISTRONIC Following Distance (The "Buffer Zone") This is the tactical override. The distance setting on the steering wheel changes the distance at which the D Auto "Brain" will begin to apply regen.
The jarring, "brake check" stops are the result of a specific, high-conflict combination: the foundational AI set to Dynamic, the Drive Mode set to Sport, and the DISTRONIC distance set to its Closest setting. You've essentially programmed every layer of the car to be as aggressive and last-minute as possible.
The Final Layer of Mastery: The Individual Mode Override Now, here's the "insider" detail that allows you to take complete control. The main Drive Mode button is just a shortcut to a pre-packaged bundle of settings. The real magic is in the Individual drive mode (Settings -> Vehicle -> Dynamic Select -> Individual). Here, you can unbundle the settings. The key is the "Drive" parameter. Setting this to Sport will give you the same aggressive regen "bite" as the main Sport mode. The "pro move" for a truly customized and smooth experience is to create an Individual setting with the Drive set to Comfort (for silky-smooth regen) but the Suspension and Steering set to Sport (for sharp handling). This gives you the best of both worlds.
For those of us drivers who desire to be the masters of their domain, it's on us to understand these interacting layers. The path to perfect smoothness is to create a congruent system state: set the foundational Driving Dynamics to Comfort and the Drive Mode to Comfort. This instructs the entire matrix to prioritize gradual, early adjustments.
With all that said, here is the definitive, corrected paddle logic based on this "two-system" model.
Left Paddle (Tap to Increase Regen):
- From D+ (No Regen) -> D (Normal)
- From D -> D- (Strong)
- From D Auto -> D (Normal)
- From D- -> (No change)
- From D- -> D
- From D -> D+
- From D Auto -> D+ (No Regen)
- From D+ -> (No change)
- From any mode -> D Auto
Quick question, I read where see you had a 23 450 and now a 24 580 and I also read that you were not necessarily a fan of intelligent recuperation with your 23' but you now are with your 580, or you now at least appreciate it? I am not sure I am remembering your thoughts and writings accurately? Do you think if you had your 23' again you might even like intelligent recuperation with it, "knowing what you know now about the 4 Layers and their interplay? I am trying to forecast what degree of success/utilty we might have with our 23' EQS and intelligent recuperation!
Thanks again for this great explanation!
What changed with my '24 wasn't the car's technology—your '23 has the exact same system. What changed was my mental model of what the system is actually for.
I was initially judging D Auto through the wrong lens, and that's the key to the whole puzzle. The reality, which I now appreciate, is that you have to separate the system's tool from its purpose.
For D- (Strong Recuperation), the tool and the purpose are the same: apply maximum regenerative braking. It's a simple hammer that only asks one question: "Is the driver's foot off the accelerator?"
D Auto, on the other hand, is a carpenter. Recuperation is just one tool in its bag—the hammer. Its real purpose is intelligent momentum management. Before it even thinks about swinging the hammer, it's asking a dozen more sophisticated questions based on its full sensor suite—radar, cameras, and navigation data.
Here's a more granular breakdown of what it's actually doing:
- Following Traffic: It uses the forward radar to smoothly bring you to a complete stop behind another vehicle in traffic, all without you touching the brake.
- Anticipating Turns and Roundabouts: The system reads the navigation map data. As you approach a turn, an intersection, or a roundabout that requires you to slow down, it will proactively apply regenerative braking for you.
- Adapting to Speed Limits: Using its cameras to read speed limit signs and the map data for upcoming speed zones, the car will automatically use recuperation to slow you down to the new, lower speed limit as you enter that zone.
- Responding to Topography: The navigation system knows the topology of the road ahead. D Auto will automatically reduce or disable recuperation as you approach an uphill slope to conserve momentum, and it will increase it on a downhill slope to control your speed and harvest maximum energy.
That single difference in the underlying question is the entire genius of the system. Once you stop caring about recuperation as the primary goal and start viewing it as an intelligent driving aid, its behavior makes perfect sense.
When you pair this suite of functions with DISTRONIC on the highway, you end up with two distinct, perfectly complementary systems: DISTRONIC is your tool for high-speed cruising, and D Auto is your tool for managing the complex, variable-speed world of surface streets.
Frankly, I could care less about the regenerative abilities of D Auto now. I appreciate it for its other functions—for how it seamlessly manages the car's momentum, allowing for an incredibly smooth and low-effort driving experience.
So, to answer your question directly: yes, if I had my '23 again with my current understanding, I would absolutely appreciate D Auto in the same way. You are in a great position, because you get to start from day one with the correct mental model, which will allow you to get the most out of the system without the initial frustration.
After much testing, this is my theory about the Distronic and Intel. Recup. The system can only see x amount of distance ahead. If you are going 100 mph with these systems on, and there are dead stop traffic half a mile head visually, the system cannot see it. It will continue to barrel ahead. I'm certain there is radar scanning distance (and it is not as far as your eyes can see) limitation, and that even at 100 mph, the system will brake with ABS to stop the vehicle from collision once an object is within range. I do not know what that range is, but I suspect It's likely closer to 500 ft or less, or whatever it is when you set the distronic to the farthest setting.
While these nannies can ensure that you will not hit the car in front, it doesn't guarantee that you will not get rear ended by the vehicle in the back because if these emergency stops.
For me, the regen modes are driving mood selectors.
That's the tell, isn't it? The moment you find yourself overriding the system not because it's failing, but because its internal logic feels so alien. Your take on the sensor range gets right to the heart of that paradox.
It explains the jarring, almost frantic acceleration into a newly opened gap after a slowdown—the digital equivalent of having zero chill. More importantly, it explains the profound sense of unease when approaching stopped traffic from a high speed. Your eyes and experience see the static reality a half-mile away, signaling for a long, gentle coast. The car, however, remains committed to its speed until it enters a much shorter, pre-defined tactical bubble, at which point it brakes with an efficiency that is technically impressive but intuitively all wrong. Like you, I often find myself intervening, not because I doubt the car will stop, but to impose a needed layer of human foresight onto the process.
What this all points to is a fundamental difference in processing: the car is playing checkers, while an experienced driver is playing chess.
The system is a master of reaction. It sees the piece directly in front of it and makes the optimal, programmed move. But it has absolutely no capacity for anticipation. It cannot see the state of the board five moves ahead, cannot sense the subtle, predictive flow of traffic, and cannot deviate from its rigid, reactive logic. It’s been engineered for last-second collision avoidance, not for the art of smooth, predictive driving. That gap between its reactive capabilities and our human, anticipatory nature is the source of every moment of white-knuckled anxiety.
On your final point, "driving mood selectors" is the perfect term for the regen modes. I think of it as a rheostat for driver engagement. Sometimes you want the deep immersion of one-pedal driving, and other times, you just want the effortless coast of a classic Benz. An always-or-never approach misses the point entirely.
It's a brilliant piece of engineering that's still in search of a little wisdom.
