EQS EQS (V297) sedan
Advice and thoughts on the EQS
Old Jan 7, 2026 | 07:11 AM
ua549's Avatar
Actually the larger 21" wheel size will be better for wear because it has fewer revs per mile than a similar tire with a 19" wheel size (approximately 675 vs. 725).
That being said, the actual tire construction and compound is the real determinant of tire wear, not wheel size.
Old Jan 7, 2026 | 10:45 AM
Kirium's Avatar
Good to know. I wondered if tire wear would be better on a smaller wheel. My m850i averages about 50,000 miles per set. I understand theres probably no way with the EQS it seems
Old Jan 7, 2026 | 11:20 AM
ua549's Avatar
50k miles on a set of tires is better than the norm. Do you live in a cold climate? I live in a hot climate and never get more than 20k miles on a set. IMO it is due to tire heat.
Old Jan 7, 2026 | 01:54 PM
Kirium's Avatar
I live in Oklahoma. We get everything here.
I've always gotten a lot of miles on my tires. Maybe it's how I drive and maintenance?
Due to the different front and rears I usually just rotate side to side. I also have never driven it during winter conditions/snow as we have a different vehicle for that.
Old Jan 7, 2026 | 02:02 PM
ehildum's Avatar
2024 EQE Sedan
I think the tire's tread wear rating is what you should look at more than being concerned about the wheel size. The larger wheel sizes cost you a bit of range, so if that is a concern smaller is better (gains you about 5-10%).
Old Jan 7, 2026 | 02:28 PM
Kirium's Avatar
Again, I've only owned the car for a week. So trying to learn best practices. You're right in that I'm looking at tread wear and the average miles expected on tires. It does seem the 19" get better range, also the tires are less costly. So yes two different things: 1. best tire options 2. what is the best for range and comfort? wheel size speaking.
So I'm looking at both to learn, I've been reading the tire thread to see what people are having success with. It seems most EQS owners in the threads have 20", maybe I'm wrong, but the 21" options seem a bit more limited. I was even toying with eventually going non run-flat which it seems some do.
Just trying to learn and plan from the experience of other owners.
Old Jan 7, 2026 | 09:32 PM
  #32
MB37's Avatar
23' EQS AMG
There is a tire thread somewhere in here. My original tires lasted 11K or 13K (I can't remember). All 4 were bald on the inside tread. They were the factory Michelin Piot Sport EV 21". In short, they suck. The DWS 06 staggered now with similar mileage of 11K (285 on the rear vs. 275 on the fonts), they look great with plenty of treads left. As quiet as the Michelin, too.
50K miles on an m850i? What tires do you have on it? That's crazy. My F02 750Li with ARS and IAS barely lasted 30K on DWS. The negative camber is pronounced on these bimmer boats.
Old Jan 7, 2026 | 09:33 PM
  #33
MBNUT1's Avatar
2010 E350 4Matic
If you replace EQS 19 inch wheels with EQS 21 inch wheels there will be like 0.5% difference as the larger diameter rims will have lower profile tires.
  • EQS Sedan (V297):
    • 19-inch: 235/55R19 on 8Jx19 rims
    • 20-inch: 255/45R20 on 8.5Jx20 rims
    • 21-inch: 265/40R21 on 9.5Jx21 rims
Old Jan 8, 2026 | 01:01 PM
  #34
ehildum's Avatar
2024 EQE Sedan
I am not sure fewer revolutions is really true. The smaller diameter wheels typically use a tire with more sidewall for a roughly constant overall diameter. The car would look a little funny if the wheel well was not filled in or filled with a small tire, and that would also mean they need to adjust the speedometer for the different wheel/tire options.
The range impacts come from having a larger mass of wheel to spin up when accelerating. Larger wheels also have larger moment of inertia that needs to be overcome compared to smaller wheels as the metal is farther from the axis.
Old Jan 8, 2026 | 02:31 PM
  #35
ua549's Avatar
As I mentioned, my post stated similar size tires. Changing tire sizes can affect both the revs per mile as well as the distance travelled for each revolution.
As far as moment of inertia is concerned, you are assuming that larger diameter wheels have greater mass. That is not a given. Magnesium rims can contain 20% to 30% less mass than aluminum alloy wheels of similar design.
Old Jan 12, 2026 | 07:06 PM
  #36
IdeeX's Avatar
EQS 450+ SUV 2024
The units that come with the car are usually 7.6kW units which you can use; however, they tend to overheat and reduce charging rates. Since your car has scheduling built in, I would recommend a simple 9.6kW EVSE without WiFi and scheduling. Something like a Lectron unit will work fine. You have no need to spend money for functionality the car already has.
https://www.amazon.com/dp/B0BXP2JB64
Note that unfortunately, the car only allows charge scheduling in 15 mins intervals, and does not allow you adjust amperage. So it may be worth getting a fully featured L2 charger that allows you do both.
Old Jan 13, 2026 | 12:05 PM
  #37
ehildum's Avatar
2024 EQE Sedan
Right. The 15 minutes granulaity works fine for me, and as I use a plug in unit the amperage is fixed already.
Old Jan 13, 2026 | 01:29 PM
  #38
Kirium's Avatar
I'm using a EVIQO Gen 2 and so far it's been great. I just connected it to a 14-50 and I'm getting just over 10 kwh on a charge. I've only charged a few times so far but from about 48% to 80% it's been taking just over 3.1 hrs
I'm going to run it down to may 10% and then charge to 80% and see the timing.
Old Jan 15, 2026 | 11:31 PM
  #39
IdeeX's Avatar
EQS 450+ SUV 2024
I also live in a hot climate. Changed my rear tires at 20k and 50k miles, but still on my original OE front tires. My front tires are likely to get to 60k miles, currently at 55k miles. Not surprised since I have the rear wheel drive SUV, so the rear tires would wear faster due to regen braking, rear steering, and all the acceleration. And since I do mostly highway miles, with minimal turns, the front tires are not as utilized as the rear.
My advice for purchasing tires is first ensure you get both the treadwear and road hazard warranties. Then you choose the highest miles/$ tire available, based on the treadwear warranty. That way even if the tires wear faster than expected you simply get reimbursed for the remainder of the unused mileage of the treadwear warranty.
