Towing with the G550 7 speed tranny
Old Jun 29, 2009 | 10:31 AM
ivanj's Avatar
Yugos only
I tow a 21' boat with a Uhaul class 3 hitch (<$400 installed) on my 2002 G500. I only do it several times a year for a max of 100 miles one way.
I have heard that the new 7 speed is not yet proven for towing even the MB brochure says it can.
Any real-world or dealer insider info?
Old Jun 30, 2009 | 07:23 AM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
If you are in North America, the new G550 (the only G with the 7G-Tronic) does not have provision for a trailer hitch. It can't be done. Totally nuts!
That being said, I have pulled a 2000 lb trailer with the 7G-Tronic in my ML with no problems.
Old Jun 30, 2009 | 06:40 PM
ivanj's Avatar
Yugos only
You're right.
There is no tow specification given for either the G550 or the G55 AMG in the Mercedes USA SUV brochure I have.
The GLXXX, that weighs approximately the same as the G550, is rated for a class 4 hitch or 7500 lbs.
My 2002 G500 had a class 4 hitch option from MBUSA. It was $1800 plus installation, oh, and a 90 day backorder.
I went for the Class III hitch from Uhaul - order it Monday, it was ready by the weekend for <$400 installed.
Old Dec 5, 2009 | 07:46 PM
ehepworth's Avatar
G550 2009
Figure this out yet?
Has anyone determined how to mount a standard US tow hitch receiver onto a 2009 G550?
Old Dec 6, 2009 | 07:08 AM
DUTCH's Avatar
You can't.
I know of a fellow who traded his 2009 G500 in at 900 miles on a Chevy Tahoe, because the G could not be set up to tow.
Old Dec 6, 2009 | 07:36 PM
ehepworth's Avatar
G550 2009
Thanks--ever heard of any after-market success doing this?
Old Jan 3, 2010 | 12:08 PM
emayer's Avatar
MB
Below are a few links from the fourbyfourclub (Thanks!) in respect to the W463 tow hitch and brake controller installation for US and Canada models:
http://fourbyfourclub.com/Manuals/W4...stallation.pdf
http://fourbyfourclub.com/Manuals/Br...ectric-Install[1].pdf
A few important caveats. The above instructions are for the 463 chassis which should be applicable with the MY '09 changes as the overall vehicle structure remains the same. What has altered significantly are the towing capacities. These are taken from the German spec sheet:
G550 unbraked 750kg/ braked 2850 kg
G55 unbraked 750kg/ braked 3500 kg
In either case the factory spec tongue weight is 12%
I've towed using an aftermarket hitch with a 2005 G500 in the past. I'm currently looking to obtain a G55 with the intent of towing an approx 4500 lb load also. Hope this helps!
Old Jan 3, 2010 | 12:28 PM
DUTCH's Avatar
All well and good, except that the vehicle structure has not remained the same. The mounting plate on the frame is no longer present on 2009-2010 MBUSA G500's. There's not any place to mount the hitch.
I know of a guy who sold a 2009 MBUSA G500 with less than 1,000 miles on the clock, because it could not be set up to tow.
Old Jan 3, 2010 | 03:02 PM
emayer's Avatar
MB
Very interesting feedback, thanks. I'm surpised to hear the US G500s structurally are different than the rest of the world. Dosen't make sense economically or otherwise. I do know for a fact that the hitch can be installed on current G55s. I'm wondering if there are any motivated G550 owners out there willing to post some pics of the rear undercarriage? We should be able to then see what the possibilities are.
Old Jan 3, 2010 | 03:13 PM
DUTCH's Avatar
I guess it depends on your definition of "current". Call a dealer to ask them.
This has been discussed at length on the forum where G-Class enthusiasts congregate; and is old news..
Old Jan 3, 2010 | 03:24 PM
emayer's Avatar
MB
Dutch,
You are correct, though while this may be old news for some, there will always be those looking for detailed answers. Hence this forum and the original poster's question. Below is a link with visual proof as to why a hitch cannot be installed on the MY 2009+ G550. Turns out the fuel tank configuration is different for the US, necessitating removal of the mounting plate. I will try to reconfirm in the next few days as to whether this applies to the G55 as well.
http://www.clubgwagen.com/forum/view...92&hilit=hitch
Old Jan 3, 2010 | 03:48 PM
DUTCH's Avatar
Dutch,
It's not the fuel tank configuration itself that is different in the US. It's the same as the ROW.
It is the US NHTSA/DOT requirement for puncture resistance in a rear end collision that's different from the ROW; thereby necessitating a different protection plate and the elimination of the hitch as a possible puncture causing implement.
PS - the reason for my response about "old news" was the fact that a newbie was questioning 25+ years of experience with the G.
PPS - The main differences between the G550 and the G55 are the engine and the transmission and some minor differences in brakes and suspension. I think you'll find the fuel tank located in the same puncture potential location.
Old Jan 3, 2010 | 04:13 PM
emayer's Avatar
MB
Forgive me for inquiring about a more detailed explanation for your inital response. I didn't realize that a "newbie" (of 3 years and 6 MBs) wasn't entitled to further discussion about a particular topic of interest to us all. In this instance, I hope you can see fit to realize that some of the confusion stems from the fact that the US MB site currently states that the MY '10 G550 is capable of towing 3500 lbs.
Your (eventual) detailed explanation is perfectly logical. Given the potential of these vehicles, one has to wonder if a workaround will ultimately be developed.
Old Jan 3, 2010 | 04:31 PM
DUTCH's Avatar
If it is, it will probably not be done by MBUSA. They have never wanted this vehicle in their lineup; and still don't. They would have been happy to see it end with the Grand Edition; but were told by Stuttgart that they would continue to market the vehicle.
As an aside, the MBUSA Vice President for Marketing does not even know the proper spelling of the vehicle. That doesn't portent for a very favorable future for it in the US. I, personally, think it's part of MBUSA's plan. Because it won't tow, it cuts down the number of sales. They can then go to Stuttgart and say: "Listen to what we told you. This vehicle just won't sell in the US."
Old Jan 10, 2010 | 10:14 AM
laxexquis's Avatar
2007 S550
Can it Possibly be that the G55 can tow because it does not have the 7-speed tranny that the G550 has?
I am trying to choose a winter car, Range Rover or a G55.
I personally would rather have the G55, but sometimes think the RR is a better luxury 4WD car,
is the G55 as comfortable as the RR?
John
Old Jan 10, 2010 | 11:06 AM
DUTCH's Avatar
Nope. The newer G's cannot tow because of the location of the gasoline tank and its susceptibility to puncture from a rear end collision. The hitch is looked upon as a puncture instrument.
Old Jun 3, 2010 | 10:33 PM
KKilo23's Avatar
http://www.renntechmercedes.com/showroom_other.php
Old Jun 4, 2010 | 02:27 PM
emayer's Avatar
MB
Thanks for the link and to Renntech for devising a solution. Figured it would be a matter of time....
It'll be curious to see if MB incorporates a solution in the rumored 2011/12 revision. Guess we will have to wait and see!
Old Jun 14, 2010 | 07:09 PM
transferred's Avatar
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
Thx for the info dutch
Good for him, wow bet he was p!ssed when he found out...total joke from Benz, this thing's meant to be a truck...no excuse not to be able to tow at least 5k when japanese and euro rivals are rated to tow 8,000-9,000 pounds...
-Rob
Old Jun 15, 2010 | 07:27 AM
emayer's Avatar
MB
Dutch is absolutely correct with his prior statements.
For clarification, the G55 is rated to tow 3500kg (2850 kg for the G550) and does so everywhere else except the US. The issue in this country is the fact that the hitch assembly was not approved due to fuel tank puncture risk.
As noted in a previous post, Renntech has nicely devised a solution to this problem. That said, it is weird that MB didn't rectify the problem as the solution doesn't appear to be costly.
Too bad Dutch's friend sold the truck...
Old Apr 12, 2016 | 09:50 AM
priapism's Avatar
'06 clk55 : '18 Canyon Duramax: :91 325i : #33 So Cal Spec E30
Sorry to ressurect a thread from the dead, but I've been researching Gs for tow vehicles. I saw a G550 with a tow hitch on it yesterday. Has anything changed? Or maybe he changed the badge? It looked pretty new, and the hitch looked to be a standard "never been used" factory unit with the cover still on it. But it was definitely a class 4 receiver.
Sorry but I did not snap a photo.
Old Apr 13, 2016 | 05:53 AM
ajm0623's Avatar
'25 740i; '15 targa4s; '24 cayenne
i just bought a new 2016 g550 (i'm states-side), and it does have a tow *provision* as you can see in the photo below; however, it requires an ("approved") after-market hitch. according to the 2016 brochure, the rig has "trailer stability assist" that provides for yaw control and states that it can tow up to 7,000lbs.
Old May 1, 2016 | 09:24 AM
slk23022's Avatar
SLk230, CLK500
2013+ certainly have the tow included.
