Rims damage spreading 2010 G55
Old Oct 30, 2011 | 08:37 AM
hbahrain's Avatar
Mercedes:G55 AMG 2010, Lamborghini LP550-2 Balboni edition, 2011 Chevrolet Silverado,2015 Bentley GT
Hi, I have a 2010 G55 and i noticed a few months ago that around the Mercedes star in the center of the rim there is some kind of rust or something developing. First it was on just one of them now it has grown significantly on one and is starting to come out on the remaining three, i tried cleaning its not dirt and the car wash i take my car to say its some kind of rust but i don't know.
If any of you guys can help me in anyway in telling me what it is or how i can avoid it spreading or how to fix this and if any of you had the same thing with your car i will highly appreciate it
(picture attached)
thanks in advance
Attached Thumbnails Rims damage spreading 2010 G55-img01110-20111030-1221.jpg
Old Oct 30, 2011 | 06:45 PM
PCH's Avatar
PCH
'10 G55, Challenge Stradale, 997.1 GT3, E63 Wagon
You have a warranty, I suggest using it. If the rims are actually rusting at least you'll have a documented repair order with MB that may serve you in the future should anything need replacing. You may also want to check the composition of the wheel cleaner being used. Many detailers and car washes still use acid based wheel cleaners which basically attack the wheel surface and ultimately will dissolve metal.
Old Nov 22, 2011 | 03:50 AM
calemonlaw's Avatar
Honda
I need to replace the stock split rim wheels on a 1948 Mercury 1 ton truck. Will 8 standard 8 bolt Ford Truck rims fit properly?
Old Nov 24, 2011 | 05:56 AM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
Looks like an ambulance chaser trying to peddle his wares through a link in his sig!
Old Nov 24, 2011 | 09:20 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
Those are alloy wheels which wont rust.. It looks like oxidation under the clear coat. I would have the dealer look at them it seems like a waranty issue.. The only time i have seen this not be covered is when a tire shop banaced a guys wheels incorrectly and scratched up the center bore and cause it to corroide.. did you have your tires balaced
latley??
Old Dec 22, 2011 | 12:22 PM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
All of the nuts surrounding the MB star in the center of the wheel are turning red and corroding. Is this covered under warranty???
