2011 G550 Facelift Advice?
Old 06-23-2017, 10:45 PM
Caskieatl's Avatar
G550
Originally Posted by MR-H
Good looking rim no question, but why priced so high- almost 2k per rim? Is it normal?
How is the ride? Is it sensibly more rough on the steering?
Ah, I see. The screwed up the price on the re-list. Its not 9890K, it should be 980.90. Send them a message.
Old 09-26-2017, 01:28 PM
YCHU's Avatar
2008 S550, 2004 G500, 2020 Cayenne
Caskieatl,
I've just got similar, if not the same, wheels in satin black and I think the lug bolts they put on are little short although that are saying otherwise.
Did you use the ball seat or conical seat lug bolts for your wheel?
How do you measure the rim thickness and shanks going into hub holes?
Thank you
Old 10-02-2017, 01:33 PM
Caskieatl's Avatar
G550
Originally Posted by YCHU
Caskieatl,
Thank you
I used BALL SEAT lug bolts. I measured the lug bolt length first, then stuck a bolt into the hub, and measured the bit sticking through. I then subtracted that number from the original length to get the thickness of the hub at the hole. Check out this post where I have pictures and measurements. Also in that thread is a link to where I bought them. https://mbworld.org/forums/g-class-w...ml#post7175078
Old 10-02-2017, 02:12 PM
YCHU's Avatar
Thanks for the info. I've ended up using the conical seat because the bolt holes looked rather like corn shape, tapered angle.
Old 10-02-2017, 02:31 PM
Caskieatl's Avatar
G550
yeah, I think it really depends on what the rim bolt seat arrangement is. Since mine were MB clones they had the ball seat, but other brands may use cone. so long as they seat solid with no wobble, you're ok.
Old 10-27-2017, 03:25 PM
MercHouston's Avatar
2003 G500, 2006 SL500, 2014 C250, 2015 ML350, 1990 190e 2.6
so how are the wheels, are they decent quality? they look great on your G and match really well with the smoked lights by the way.
Old 11-11-2017, 04:03 PM
  #32
ET550's Avatar
2008 CLK 63 Black Series, 2013 G63, 2014 RS5 Coupe, 2013 JKUR 10A
Originally Posted by Caskieatl
OK, so here's some clarification on the Lug Bolt situation. For my OEM wheels, the original OEM bolts were stripped and cross threaded. When my OEM wheels came off to install the new wheels, the RIM supplier bolts were too short. So, I had to put the old OEM wheels back on until I could get longer bolts that would safely mount the new rims properly. So, I had to buy OEM bolts to re-install the OEM wheels for about a week. UGH.
My local MB dealer service department manager turned me on to EZAccessory where I got new bolts that fit the new rims safely to a proper depth. The OEM Rim thickness is greater than my new rims which are 6mm) so the old OEM bolts were about 10mm too long. The rim supplier bolts were too short for safety.
I've attached a photo of the length of each bolt. The proper bolts are 35mm threaded shank with 29mm going into the hub holes.
I recently purchased those wheels as well for my winter tires. However, the only 35mm ball seat lug bolt currently on the EZAccessory site is a 14mm x 1.50 which has an overall length of 59mm and not 55mm as you indicated in your drawing. Is that the one you purchased or is a 12 x1.50 required? Do you think the 33mm will fit with a 57mm overall length?
Quick Reply: 2011 G550 Facelift Advice?
