Rattles inside my G63
This is my first post here, I recently got 2014 G63 from a friend, who babied the car, it came in a perfect condition with 24k miles on it.
So far I have been enjoying the car, put 21 forged wheels on it, Brabus hood scoop and brabus lip. My biggest concern is probably around 1 million rattles inside the car, and some of them are 100% not normal. More info below:
1 - lots of rattle / sound coming from under dashboard when driving over small bumps or potholes. It sounds like dashboard came out of its "hooks" and just jumping around on bumps. Anyone else has this?
2 - noise from the back seat under the plastic cover. I took it off and put a lot of sticky foam on the metal bars, it seems quieter, but still I can hear some rattle on bumps, maybe not from backrest, but bottom part of the seat. Any idea / suggestions?
3 - squeaking noise from passenger seatbelt lock (when in use) OMG this started like 1 month ago and damn its loud, any minimal bump on the road starts this squeak. What should I do?
4 - Rattle from the trunk? sounds like a curtain bar, but I put foam on the sides of it so its doesn't move around. I tried driving without this bar, but noise is still there, maybe something in that area under the plastic?
5 - noise from the drivers seatbelt (top part) right next to my ear, very minimal noise, but since its right next to my ear, I "enjoy" it through the whole ride.
These are all for now, please anyone let me know how to cure these. I am getting tired of this orchestra inside the car pretty fast
Attachment 353312
"this specific vehicle is exposed to extra rattles due to its nature"
I am taking a car to a dealer tmrw, let's see what they can do
Also, try test driving similar vehicle at the dealer with 20" wheels. See if you might hear similar rattles.
Im sure each g-wagon will have "some" squeaks and rattles... some might have them more then others.
Under the dash, could be something bolt/nut got loose or something is rubbing agains something else.
Under the back seat, could be around the subwoofer or loose bracket on the seat. Sometimes they have a tool kit under the back seat.
Seatbelt buckle might need to be replaced.
In the trunk, could be a spare tire rattle...
Driver side seatbelt area, could be rattle from the seatbelt hight adjuster. Try adjusting the hight and see if it does anything.
I will try to test drive a brand new G wagon tmrw at the dealership and analyze it.
Noted on noise under the dash, I think the only solution for them is to take it off and check all the parts.
Back seat tool kit - I took it off right away as it made a special noise while driving, so I figured that was it. Other noise is still present.
Hope so on seat belt buckle.
I removed spare tire at all, no more noise from there as well
Tried adjusting the seat belt, noise is present at any position. I will post updates once these will be taken care of
Go outside while parked and push on the front of the hood side to side. They can make loud squeaks sometimes thats sounds like its in the dash, and you can isolate the metal to metal contact on the front tabs if need be. Many times on a parked vehicle you can replicate some sounds by just pushing on the suspension, than they are easier to find. Have a pusher helper.
Rear door latch may be out of adjustment and or spare tire, push on your spare tire and door while its parked to see if you can get it to replicate. A good thing to check is all your door seals, including the back door. Wash them all and lubricate them with the appropriate stuff. Flexing and movement can make them throw weird squeaks out. Try some Krytox on them. I believe VW makes it in aerosol and grease and its seal compatible.
The seat belt unit. Just replace it if you have to. Maybe you can take it apart and lubricate it internally. Squeaking is friction, so if you can get something in-between the two culprit parts, you are good to go. Always start with the easy squeaks first and save the bad ones for last. Last thing is make sure there is nothing in the interior somewhere thats making the noise. First thing I always do is empty out the stuff from the glove compartment, etc. I have had sunglasses rattle before and trick me.
Rear Door - interior facia at top around rear window on both sides of brake light rattled against metal door. sprayed gap where facia meets metal. Rattle completely stopped.
Driver door - same thing... Interior facia along front of driver door around window frame squeaking during road movement. Application of lithium spray in gap between facia and metal door frame stopped all noise.
Rattle in/near rear seats - opened compartments in rear seat floorboards to adjust/tighten tools, jack, etc... Also lubed rear seat to floor latches with Lithium Spray. All noise ceased.
Still have exterior squeaking that I have yet to isolate. Could be hood, brushguard, suspension or god knows... but I am on a mission to find it.
Good Luck!
