4x4² carbon visor LED light activation harness
Old Jun 23, 2017 | 10:14 PM
Las Vegas G's Avatar
2005 LeTech Portal G500, 2009 SL63, 2014 LeTech Portal G63, 2016 S65 Coupe
Here is the wiring kit to turn on the LED lights in the carbon visor on the US model 4x4².
I currently have this one only, more on the way.
Old Jun 23, 2017 | 11:51 PM
NYCBenz's Avatar
6x6 | 4x4
email sent Bill!
Old Jul 1, 2017 | 07:39 PM
CrazyMD's Avatar
g class
I have a much easier harness using factory mbz connectors. I made 2 extra that I'll have for sale. Pm me if interested
Old Jul 1, 2017 | 08:11 PM
The way you did it is a little dangerous, my kit connects into the CAN to correctly control the lights. Also comes with an upgraded antenna.
Old Jul 1, 2017 | 08:57 PM
CrazyMD's Avatar
g class
Not dangerous at all. Simple electrical connection. Your way costs an arm and a leg and has many more parts. How do you think the 2 front leds are connected. Or all the Orange marker lights. They don't each run off their own system. The lights are all wired together.
Old Jul 2, 2017 | 12:55 PM
When I was in Germany last month and met with the engineers at LeTech and discussed the "jumper wire" method of activating the lights they said "it is a little dangerous" and the CORRECT way to do it is to install a complete separate harness for these LED's along with a relay that connects to the CAN system.
Hey, it is not for everyone! But for the 4x4² owner that wants to do it the proper way and can afford to do it, this is the kit to go with.
Old Jul 2, 2017 | 01:51 PM
CrazyMD's Avatar
g class
I understand you're in the business of selling stuff and that's fine. But to come on a forum and call it dangerous to add 2 led lights onto a set of other led lights lowers your credibility as someone who works on these vehicles.
Most people understand that an led light draws much less current than does a standard light bulb. The led lights are driven by a 5v light driver. The 2 front led lights by the headlights are connected together. When branching off them to add 2 more led lights, the current draw is minimal and voltage drop is about .2 volts which I tested.
We are not talking about branching off the power running to the timing sensor of the engine to create something "dangerous". You're talking about simple electrical wiring and at the absolute worst case if it was "dangerous" the "danger" would be blowing a fuse or damage to an led light.
The same guys at LeTech and Brabus told me I shouldn't put 37" tires on my car (as I was one of the first in the US to get a 4x4 and change my tires) because the axles weren't designed for it even though Mercedes and You are selling 18" beadlock wheels to be used with 37" tires.
Also, the Mercedes Benz dealer in Atlanta will activate your upper LED lights using the same exact method and harness as I have. They will warranty the work as well. Anyone can take their truck to them and have the upper LEDS activated and the way they do it is the "dangerous" method I chose.
To to date I have more than 12k miles on my car with my "dangerous" led lights and 37" tires my axles weren't made for. I think life will be ok.
Old Jul 2, 2017 | 02:45 PM
NYCBenz's Avatar
6x6 | 4x4
...Your way costs an arm and a leg and has many more parts...
FYI, we purchased Bill's Adaptors, and are having the Dealer install.
When it comes to "accessorizing" a $240k vehicle, cost is generally not an issue.
CrazyMD, you are definitely one of the few who decide to do the work themselves, and your work is astonishing to say the least.
The majority of owners who can afford this truck definitely won't be trying to tackle projects like these on their own, so we are happy to pay the premium for a product done right, and then pay professionals to install said product.
To each their own, let's keep driving.
Old Jul 2, 2017 | 02:52 PM
CrazyMD's Avatar
g class
Right, but to have Bills kit installed on your vehicle its likely your headliner and carbon fiber light bar needs to be removed. Thats hours of labor and likely things don't always go together the same without a broken clip here or there.
The kit Im using doesn't require any disassembly of the vehicle other than simple removal of the headlight and the OCP/sunroof switch panel to be lowered.
I prefer not having the dealer or whoever else drop my headliner to activate 2 LED lights. Im all about simplicity. But yes there are always multiple roads to a destination. I just prefer the simplest and easiest road.
Old Jul 23, 2017 | 12:57 AM
XComp4x4's Avatar
2017 G550 4X4 2
He's useing the Brabus kit I just bought it Friday from brabus usa in Newport Beach CA thay have them in stock and working good deals on them
Old Jul 23, 2017 | 02:04 AM
Correct, however I get mine directly from LeTech / Brabus in Germany, I refuse to believe German Tuning Company a Brabus distributor in the USA gives a "deal" on anything.
Would be interested to know what they are charging.
I just got 8 kits in, sold 5 right away, still have one standard kit and two with black lamps.
Old Jul 11, 2018 | 07:18 PM
Romi Mirza's Avatar
4x4 squared
Mercedes-Benz
hello I would like to buy your wiring harness. Could you call me? 516.971.8390 .Thank you Romi
Old Jan 9, 2019 | 09:38 AM
Begul2019's Avatar
G500 4x4 ^2 squared 2018
email sent Bill!
I have the Same problem with roof led lights , please help me with this Bill
begulmarcos2014@hotmail.com
Old Feb 28, 2019 | 03:47 PM
LARRYZO6's Avatar
Gwagon
Gwagon visor led harness
Hello can can you please contact me I need this harness set up. Thanks
Old Mar 2, 2019 | 05:59 PM
AMGRay's Avatar
G63
Is this the kit that wires the lights up to your high beams?
Old Mar 4, 2019 | 09:09 PM
efathalla's Avatar
2013 S550 SOLD / 2016 S63 SOLD / 2017 GLS450 / 2017 G550 4x4 / 2019 G63 E1 SOLD / 2019 AMG S63 COUPE
I believe yes, its the Brabus kit that requires drilling in the roof!!
I did mine and it factory looking switch.
Old Mar 31, 2019 | 10:31 PM
Begul2019's Avatar
Wiring harness kit
Please contact me for Whatsapp in this number
+584140325070
im interest in this kit. Thanks
Old Dec 25, 2019 | 01:16 PM
Goletiani's Avatar
2012 CLS63AMG Kleemann K3
Hi all, I need to buy the roof spoiler wiring kit. Can you please contact me on WhatsApp or Viber +995599555115
Old May 18, 2020 | 05:56 PM
Das_Wagen's Avatar
2018 MB G550 4x4²
Hello! New to the forum and to be honest this wiring harness is what brought me here! Ive learned a lot about the my G from this forum and happy to become a member. Now back to the reason im here, is this wiring harness still available? If so im very interested in getting my factory light bar working.
Old May 28, 2020 | 01:14 PM
CrazyMD's Avatar
g class
Hi, I do have a harness left. You can private message me to discuss.
Old Dec 17, 2020 | 12:11 AM
jmoorevt's Avatar
Nissan GTR
Hey CrazyMD Was wondering if you had any more harnesses for the G Squared lights? If so would you mind letting me know how much and what the lead time is? Thanks!
jon@dreamworksmotorsports.com
Old Jan 13, 2021 | 05:20 PM
Romi Mirza's Avatar
4x4 squared
Hello how can I buy a harness for my LED roof light bar?
Old Feb 1, 2021 | 02:42 PM
Romi Mirza's Avatar
4x4 squared
Hello can i buy one from you???
Hello I would like to buy one from you my email is boson5779@gmail.com
Sincerely
Romi
Old May 17, 2021 | 07:27 PM
mintytoo's Avatar
G square
Hi CrazyMD, let me know if you have another harness , minty78@gmail.com Thanks
Old Jun 10, 2021 | 04:40 PM
paqueras's Avatar
G320 CDI, C32 AMG Sportcoupe, GLK300 4MATIC
Drilling the roof? No way.
Just found a way to run the cables through the A-Pillar. I just installed a 50" single led bar in my roof rack and i run the cables through the A-Pillar directly to the positive and negative harness in the engine bay. Mine is a 2008 G320 CDI.
