ENGINE upgrade for GE 280 cabriolet
If you have the cash or the know how and time, you can put in an M117:
The 617 turbo is the easiest swap, most available and reliable engine.
What will change is motor mounts because of 2pc sedan oilpan interference with front diff, oil cooler lines 1 off donor and 1 off 300GD. Those are the bigger issues.
Finally we have found G500 engine, our plan is to use haltech injection and the original transfer case and mechanical 4 speed gear box. Please send us your comments and if is possible a budget of services
regards
VM
This car is for weekend use, you know, and our idea is not to use diesel. Finally we have found G500 engine, our plan is to use haltech injection and the original transfer case and mechanical 4 speed gear box. Please send us your comments
Regards
VM
B) Going to put a ton of strain on components built for half the horses.
C) bring only a little more torque and speed to the pavement because of the gearing through to axles.
Honestly, I believe you will have to drive this thing with it's nuts tied or risk blowing it to smithereens.
463's had have frames re developed to accommodate V8.
I would find another M110 or as suggested an M113 or even go with a non merc engine that will fit and be comparable in horsepower. Audi, Lexus, Toyota even LS or buick V6 with turbo.
Check Club G Wagon parts. There is an m110 and autobox there for $900 in Cali.
