2010 g class light bulb?
Old Apr 28, 2018 | 11:51 PM
wagonagain's Avatar
G550
Did a search but was unsuccessful so needing some advice
i have a 2010 g550. Noticed the other day that my daytime running lights are totally different. The hue on one looks like xenon and one looks like an old school halogen.
I think it’s just bc the bulb is dying so looking to purchase a replacement.
What is everyone using? Hoping to purchase one from amazon ( bc I’m lazy)
thanks for the help
Old Apr 29, 2018 | 07:18 PM
Holson's Avatar
18 G550, 24 EQB3504M
The 2010 doesn’t come with the LeD strip yet unless you retrofitted it so i think your city lights are w5w bulbs. I think the factory ones are the Philips blue coated bulbs. If you want something brighter take a look at
Philips Xtreme Vision 360 X-tremeUltinon LED Philips Xtreme Vision 360 X-tremeUltinon LED
philips makes two models: 6000K and 4000K. I find 6000K too blue and usually get the 4000K one which matches well with the factory 4300K xenon more but your call! They are both very bright. I usually get a set to upgrade cars with incandescent bulbs
Old Apr 29, 2018 | 08:55 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
You'll want 194/T10/194 wedge LEDs. Can't just be any led either, has to be canbus enabled or it'll throw error codes. Ours will work perfectly for you:
http://www.aznoptics.com/index.php?m...roducts_id=114
Old Apr 30, 2018 | 07:13 AM
invictusmaneo's Avatar
Lifted G500, GT-S, track Cooper S
Would these work the same?
http://www.aznoptics.com/index.php?m...products_id=96
I had issues finding wedge bulbs that would fit in the tiny hole into the headlight itself. The wedge on many fit fine, but the actual bulb is larger than the wedge, which prevented it from passing through the hole.
Old Apr 30, 2018 | 10:48 AM
AZN Optics's Avatar
Those would work also, but those are 4300K so color output is soft white vs pure white. Your call. Haven't had any reported issues with the v5.2a not fitting through the hole opening.
Old May 1, 2018 | 06:33 PM
scottyOTM's Avatar
06 CLS55 & 2011 G55
link is not working for me? getting this error
Sorry, the product was not found.
Old May 1, 2018 | 07:21 PM
AZN Optics's Avatar
try again, mobile app injected a white space in the link.
Old Jun 9, 2018 | 11:54 PM
wagonagain's Avatar
G550
Thanks for the replies
i just want to make sure I’m on the same page. J had trouble opening the links too
here is a pic of the light issue I’m having
yoo can see from the pic the drivers side headlight is fine but the passenger headlight almost looks like the old school halogen
what do you guys recommend for this?
thanks
Old Jun 10, 2018 | 12:17 PM
Holson's Avatar
Oh that one, the main beam. I’m guessing the yellower one is on its way out. Someone may have replaced the one that’s still bluer in the past with a newer bulb. HID capsules yellow as they age
here are some d1s bulbs
https://www.xenondepot.com/D1S-autom...lbs-s/1037.htm
replace in pairs to get consistent coloring. The 6000k and 7000k bulbs will be bluer but not as bright as the 4300k original bulbs
Old Jun 10, 2018 | 12:50 PM
wagonagain's Avatar
G550
Thanks Holson!
Old Jun 10, 2018 | 01:26 PM
AZN Optics's Avatar
We carry top end Morimoto D1S bulbs if interested. Offered in 5500k (pure white) and 6500k (white with a slight bluish hue). If you want the absolute best of the best, we also carry Osram Xenarcs.
http://www.aznoptics.com/index.php?m...=1&keyword=D1s
Old Aug 17, 2018 | 03:47 AM
SGTzAMG's Avatar
Veteran: Army
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
Go with D1S Sylvania CBB.
