Valentine 1 radar detector and polarized glasses
Old Jun 27, 2019 | 08:43 AM
NOPDK's Avatar
2019 AMG G63, Porsche GT4, 1973 Porsche 911 hotrod
For 2019 G63 is there a specific place in the windshield where radar detector is supposed to mount? I recall reading something about an area to right of rearview mirror where there isn't any coating on the windshield that blocks the radar detector reception. Is this true or can radar detector be mounted anywhere?
Any issues seeing the new dual screen dash with polarized lenses?
Old Jun 27, 2019 | 10:16 AM
CUZCO's Avatar
24 G63 23 Metris Van Past:21 G63 21 GLS63 20 GLE350 19 G63 17 G63 15 GL550 13 SL550
It can only be mounted just to the right of the rear view mirror. In your owners manual is a picture of the area.
Old Jun 27, 2019 | 10:22 AM
Crfiv's Avatar
2021 G63, 2020 Tesla Model S, 2020 Ford Raptor
From the manual
Attached Thumbnails Valentine 1 radar detector and polarized glasses-capture.png
Old Jun 27, 2019 | 10:55 AM
NOPDK's Avatar
awesome, thanks for the info! Do all US vehicles have this windshield heater or is that an option on only the cold weather package cars?
Old Jun 27, 2019 | 01:33 PM
CUZCO's Avatar
All US G63's have the windshield heater. Also I have the widescreen and wear polarized sun glasses. No issue at all seeing the screens.
Old Jun 27, 2019 | 03:31 PM
NOPDK's Avatar
Thank you for the info. very helpful.
Old Jun 27, 2019 | 09:05 PM
Mopars's Avatar
2018 G63
I have a Escort Max 360 sitting on the dash directly behind the windshield wiper arm and it works just fine.
Old Dec 17, 2019 | 10:57 AM
johnnyderm's Avatar
Soon: 2020 G63 Currently: 2016 GLE63 SUV + 97 F250HD, Before: 2013 G550, Range Rover Sport, 1984 CJ7
Mopar can you post a photo how yours is mounted? I cant seem to find a good placement. And yours works ok? @Mopars
Old Dec 17, 2019 | 11:13 AM
alistairg's Avatar
2020 G63
Originally Posted by Crfiv
From the manual
An aside... but where did you find an online / electronic manual for MY19+?...
Old Jan 11, 2020 | 10:57 PM
JAGGED155's Avatar
2021 G63
How is everyone mounting their radar detector, specifically V1, on a near vertical windshield? No blendmount available and the standard mount won’t work.
Old Jan 12, 2020 | 02:50 PM
NOPDK's Avatar
Got V1 to mount nicely after some fiddling. Here is what I did. Did hidden hardwire install to SAAVY module into OBD port. Angle of G windshield not friendly to mounting angle of detector. When you put it on windshield if points at the hood. Do below and it will point in right direction. Make sure using new larger suction cups as if they are hard and dried out won't stick well enough. Position V1 high up in area where windshield has transparent opening that doesn't block detection. Wet suction cups and put V1 into first click on windshield mount. To get V1 pointing in right direction I used a rubber test tube stopper that I had on workbench from another project. Picked up bag of them on amazon for cheap years ago. They make bunch of sizes. Tons of other things you can use for the spacer. Just look around and see what you have of right hight. You attach the stopper to the V1 with one of the 3m tape tabs that Valentine supplies for install. With V1 high on windshield the stopper is in perfect position to push it so sitting flat. See picts below. Hope this helps.
Old Jan 12, 2020 | 04:28 PM
JAGGED155's Avatar
2021 G63
thanks for the write up and photos!
Old Jan 12, 2020 | 06:02 PM
johnnyderm's Avatar
How do you see what the V1 was is alerting you to? Audio alerts? I cant see my max360 on the right of the mirror.
Old Jan 12, 2020 | 07:15 PM
NOPDK's Avatar
I can see the V1 arrows to right of my rearview mirror in that position. Works great. Have the V1 accessory module but didn't need to install that. Unit hooks up great with Savvy into OBD port put I get an alert I need to turn off every time I turn car on. OBD doesn't like things being kept in. No issues other than annoying alert. just hit that when I turn off stupid lane keeping assist.
Custom programmed sweeps into V1 years ago focused on Florida police bands and now have almost zero false alerts. Really works great.
Old Jan 13, 2020 | 07:43 AM
NOPDK's Avatar
picture of V1 from drivers seat. you can see the arrows just fine. just mount it as far right and high as possible in the window foil gap. leaves room for my EZ pass to right of detector. don't mind my big skull in the rearview mirror.
Old Jan 13, 2020 | 10:19 AM
johnnyderm's Avatar
Seems better viewing wise than my 360 but I am afraid to be looking top right while driving on highway frequently.
Old Jan 13, 2020 | 10:35 AM
NOPDK's Avatar
I can see it when I look at rear view mirror. No need to look unless it's setting an alert which with custom sweeps almost never happens. If it chirps there is a cop around. you can mount V1 accessory module in different more centered spot or use smartphone as display if you buy the bluetooth module. Have had my V1 for 15 years now and have upgraded it with new electronics 3-4 times to keep the internals current.
Old Jan 13, 2020 | 10:56 AM
johnnyderm's Avatar
Great to know. Is the V1 current or do we expect a new V2 coming soon?
