G-class rust
Just make sure that you can use the can with a thin aerosol straw. Fill the cavity behind the stripping with enough grease so that it starts to seep through the stripping (ensuring that the cavity is completely filled. Use more grease than you think is necessary.
I just wiped off the rubber really well, and although it still doesn't sit flat, it is looking a little better. Maybe sitting overnight will help regain its shape. Also wondering if maybe these rubber pieces come with adhesive on the back from the factory since back of the rubber on the top part of the windshield feels kind of sticky underneath. Maybe I could apply some weak adhesive to the corner...
What product did you use to do this?
Here is some details on Corrosion Block: https://www.nocorrosion.com/
Here are the product offerings from Lear Chemicals: https://learchem.com/products/acf-50.html
Looks to be safe on rubbers. Now I just need to locate all the pain points. Is there a list and pics of all the locations
As for pain points, figure on spraying the entire chassis. You’ll want to remove the bolts that holt the running boards to the body (you can remove one at a time so you don’t need to take the boards off) to access the cavities underneath the door sills. Spray in the drain holes at the bottom of all the doors. Get the entire windscreen surround. Use a thick grease (like Lucas red and tacky) to treat the sunroof surround (get underneath the sheet metal that surrounds the moonroof). The rear door seal is notorious for trapping water and corroding. Slowly pry it back and grease all of it, the top in particular. The rear door hinges also like to rust. You can access the backside of these hinges by removing the rear interior panel. I’m on the west coast right now but when I get back home I’ll make a quick video demonstrating how to remove the panel.
If you ever get around to the video, that would be extremely helpful and other areas I should be spraying. I'll also share my experience with these products once I get the G.
it is a common problem. I have a 2008 G500 with 70K miles that i bought brand new from Mercedes Benz of South Bay in Torrance, California, and the car is rusting away in over 10 spots, including all the mentioned areas in these comments. It is a defect! I am trying to get enough folks so that we can file a class action. I have three other MB cars at my house, and none have this issue - all stored and driven under identical conditions.
David
I don't know how I just caught it but it is still early enough along that I can probably stop it from spreading with regular surface application of grease. I might need to get up underneath again and saturate the sills with Surface Shield. Son of a *****.
Prepping for next weekend's clean, wax and will check seal and other stuff....
The windscreen will have to come off, which always cracks the windscreen so figure on having to replace that too. Depending on how deep the rust goes, it could either require sanding and repainting or plasma cutting the rusted area and replacing it with fresh sheet metal.
My guess is that you're looking at $4k.
