LeTech Roof Rack
Old Nov 6, 2019 | 09:44 PM
Ersatzs2's Avatar
'76 Porsche Turbo Carrera, '21 G63
LeTech Roof Rack
Not sure when my actual car will arrive, but the roof rack came yesterday. Really impressive build quality: steel and aluminum. Not sure what the rooftop load limit is, but the rack itself is gonna absorb a fair amount of it. It screwed together pretty quickly with an impact gun and star drive. The ladder rear mount is an amazing chunk of milled aluminum.
Old Nov 7, 2019 | 08:15 AM
horse86's Avatar
Range Rover, M5
damn! that thing is nice! hopefully the coating is heavy duty and won't start rusting.
How much did it run you? How does it mount to the roof...no drilling onto the G right and completely reversible?
Old Nov 7, 2019 | 09:00 PM
Ersatzs2's Avatar
This was about $4300 but shipping from Germany was a lot. It's really heavy. It mounts using the factory roof rack mounting points. The LeTech roof rack for the prior version was $2K more Because it had a much more complicated mounting system using the rain gutters. So, mostly reversible, the lower mount of the ladder attaches with an industrial adhesive.
Old Dec 6, 2019 | 03:53 PM
Ersatzs2's Avatar
Now that the car has arrived I can install the roof. Haven't installed the ladder yet, I want to drive it around a bit and see if I like it. Once the lower ladder mount is cemented in place, you're committed!
Old Dec 6, 2019 | 05:27 PM
vadermerc's Avatar
G550
Looks awesome - gratz!
Old Dec 6, 2019 | 06:51 PM
kim0217's Avatar
458 speciale, G63, GTC4lusso, ML63(GONE),
hows the wind noise with the roof rack on?
Old Dec 7, 2019 | 09:24 PM
Ersatzs2's Avatar
Ummm... noticeable
Old Dec 30, 2019 | 09:06 PM
adrenalinsports's Avatar
Mercedes G550
How noticeable? Like bad enough you regret buying it?
Old Jan 1, 2020 | 07:53 PM
Ersatzs2's Avatar
Re wind noise:
Well, no one buys a Gelandewagen for it’s quiet cabin; it’s got the aerodynamics of a UPS truck. However the whistling of wind around the rack is definitely discernible at highway speeds. I’ve decided I can live with it since mostly I’m at lower speeds and I dig the way it looks and the extreme functionality.
I’ve been holding off mounting the rear ladder, which is the ultimate commitment since the lower mount glues to the paint with Wurth industrial adhesive, so once it’s on its never coming off. But right now I’m inclined to do it.
Old Sep 9, 2020 | 10:49 PM
Bob Z.'s Avatar
'27 EQG deposit, '22 F8 Spyder, '20 Fat Boy
Did you ever put the ladder on?
Old Sep 10, 2020 | 09:14 PM
Ersatzs2's Avatar
Affirmative. Holds my weight too.
Old Sep 10, 2020 | 09:20 PM
Bob Z.'s Avatar
Nice...maybe someone will come out with a stand-alone ladder...no clearance for a rack in my condo's underground parking garage.
Old Sep 16, 2020 | 01:33 AM
Eric Hansen's Avatar
G500
I have the LeTech ladder on my 1997 G300td which I bought in 2017. For a ladder, I have used the ORC version which I like a lot
I think it is a little too heavy and the G wallows a bit in the curves. I have stock tire size, but it is a SWB as well.
The rack was purchased from GfG in Gotha, Germany.
I had the Baja rack on my old 1995 G320 SWB and it was much lighter and less noticeable when driving.
1995 G320
1997 G300td
Old Oct 11, 2020 | 08:30 PM
streborx's Avatar
Top Answer: 1
G550
Old Oct 14, 2020 | 10:56 AM
Ersatzs2's Avatar
very nice SWB, did that come from Europa? Yes the rack is pretty heavy. I can't recall what MB says is the roof load limit but I recall thinking that after you've added the LeTech, you were basically limited to a couple of pillows and an inflatable raft! I think it's effective load limit is very high, but MB are thinking about highway behavior. This rack is pretty extreme, basically designed for off road expeditions.
Old Mar 13, 2021 | 07:13 PM
vadermerc's Avatar
G550
Question - how do you attach stuff to the roof rack? Have you put on a rook top tent? I'm considering the LeTech rack but I don't understand how things like tents, jerry can holders etc. attach to it. Thanks!
Old Mar 15, 2021 | 01:07 PM
almostordinary's Avatar
1987 Porsche 911. 2008 G55
Each rack has a different system for attaching components.
The new ARB rack has proprietary attachment components, the FrontRunner uses a channel system.
My Ghobi rack is just mesh, so I just bolt through and use eye-bolts where needed.
Depends on the rack.
The LeTech looks like a solid surface, so I'm assuming you'd need to drill through the plates with them off the roof.
Here's an example of the Ghobi rack and some of the Stainless Steel eye-bolts I am using.
Old Apr 16, 2022 | 05:01 PM
vadermerc's Avatar
G550
Roof Rack
Still loving the roof rack? Can you post some pics from the side?
Old Apr 19, 2022 | 11:43 AM
Ersatzs2's Avatar
Yep, the rack is great. I like the distinctive look, and it is amazing how often I use it, its great to be able to just throw large objects up there and schlep them around. I no longer notice the wind noise, and frankly the G wagon is an aerodynamic disaster anyhow, so that was always a small complaint. It adds height, so pay attention to parking garages (6'10")
But it's amazingly well made, solid as a brick, and holding up well even though its parked outside 24/7.
It has plenty of tie down points just around the edges, but I bought stainless eyebolts from McMaster Carr and use them in the three lateral channels if i need more points.
Old Apr 19, 2022 | 04:03 PM
vadermerc's Avatar
G550
You win the award for the greatest most comprehensive answer to a simple question. THANK YOU! So cool to see that you can use circular eye bolt with washer vs. having to have a special clamp or "s" washer. Glad you are still loving it. I think I'm going to make the purchase - where did you buy from?
Old Apr 19, 2022 | 05:19 PM
Ersatzs2's Avatar
Thanks, I happened to be walking out there so easy to take some photos. I bought it through Viking OffRoad however their site no longer references it. Gwagenparts seems to have the LeTech for the older 463, so presumably they can order this one too.
Old Apr 26, 2022 | 09:28 AM
amgw463's Avatar
AMG G63
This is an absolutely awesome-looking roof rack. Enjoy it and do not worry about the wind noise.
Old Jul 11, 2022 | 02:31 PM
G500
Best fasteners to use with this rack is the C-channel fastener like those sold by McMasterCarr.
https://www.mcmaster.com/strut-channel-fasteners/
I had the SWB version of this rack on my 1997 G300td.
Old Jul 31, 2022 | 11:01 AM
vadermerc's Avatar
G550
Finally!
Ordered 5 months ago. Finally arrived! Love it. FYI was toled by gwagenparts.com that this rack is now officially a Mercedes part and price has almost doubled. Makes sense if you've seen the recent rollout of the G-Squared and this is the rack they used.
Old Jul 31, 2022 | 11:48 AM
streborx's Avatar
Top Answer: 1
G550
Great garage! Mine could look like that if I tore down the wall into the great room. Of course, I could then take over the entire house since I'd be single. (lol)
