how to remove front grill star logo 2013 g63
I am looking to remove the front Mercedes star logo on the grill and swap it with a black one. Tried twisting the star but don't seem to work.
Asked a friend he said he heard I need to remove the grill then unclip the star.
Have anyone done this? Is removing the grill hard? I don't want to remove the grill if there are other ways around.
Inputs are greatly appreciated!
Can it be used for supplemental lighting at night on streets and freeways ?
Or strictly for off roading only ?
Overall would you say having the light bar on with the high beam on double or triple your total brightness output shining down the road?
I also would think amber color version of this same size and and brand may be less bright compared to white color and can be used as DRL.. more useful in fog and snow perhaps .
Nice looking truck you got, like the brush guard in black!
https://www.bajadesigns.com/products...oduct-Page.asp
The only thing going with amber color is that during the daytime the amber color bar may look slightly out of place with the white OEM LED’s strips on both sides underneath the headlights.
Did you have to strip or cut any original factory wires to tap on to the high beams circuit with your method?
I also bought a Brabus badge but it seems like the base of the front grill emblem can not be separated from the grill? Can anyone confirm?
Because the base is a also a Mercedes star form so I can not just put the Brabus on.
"Front radiator grill emblem is with clips, it requires to be very gentle to not damage the radiator grill
If you havent done it before it is better to make it at workshop
Rear spare cover is simply a "sticker" it also just requires to be gentle to avoid scratching the main spare wheel cover when removing it
I would also advise to make at workshop as it is quite simple but requires proper tools and skills to make it perfectly"
Using a hairdryer on the rear one first as you use dental floss behind it will make it much easier to remove.
