2020 G63 Muffler Delete,Sounds Wicked!
Old May 7, 2020 | 05:39 PM
BurakUsta's Avatar
Ferrari 458 Cls63
Hey Guys,
Really easy job, 15x times less expensive but better than all other aftermarket systems, in my opinion.
I am stil using valves, cats are not removed just straight pipes from the cats to the tips, to use the valve button, we welded another small diameter piping next to the large straight pipes.
IDLE
When closed, it sounds %10 more than stock
When open, it sounds %30 more than stock
CRUISE
Closed, same as stock.
Open, maybe %20 more.
WOT
Now, this is the part that it just screams, i mean now i feel like this car is a completely different animal. I strongly recommend this mod to everyone.
Here is a video, sorry for the ****ty quality, youtube related issue.
Old May 7, 2020 | 07:00 PM
Bob Z.'s Avatar
'27 EQG deposit, '22 F8 Spyder, '20 Fat Boy
I just showed my wife and asked her is she wanted ours to sound like that - she said no, but I like it!
Old May 7, 2020 | 07:10 PM
drew138's Avatar
993 TT
Is that display available on the 2019 G63s where you get the gauges lit up on the right screen? Haven't played with the custom options all that much.
Old May 9, 2020 | 12:45 AM
Festertester's Avatar
‘13 911-4S, ‘21 CTR, '22 GT4, ‘19 G63
yes!
Old May 9, 2020 | 01:09 PM
G-Dreaming's Avatar
2020 G63, 2016 Range Rover LWB
"Engine data" under vehicle category.
Old May 9, 2020 | 05:57 PM
CUZCO's Avatar
24 G63 23 Metris Van Past:21 G63 21 GLS63 20 GLE350 19 G63 17 G63 15 GL550 13 SL550
G-Dreaming, could you elaborate were it is located I am not finding Vehicle Category, can't find it in the manual either. Thanks
Old May 10, 2020 | 12:39 PM
G-Dreaming's Avatar
If cannot find vehicle category then you can simply activate voice control and just say "Engine Data". It will show up on the display.
Old May 10, 2020 | 01:48 PM
CUZCO's Avatar
Thank you G-Dreaming. Got it, that allowed me to now see that you can access it from Vehicle, Dynamic Select, Engine Data.
Old May 10, 2020 | 05:12 PM
I also recently found out that I can activate massage by saying..”massage on”
too lazy to read the manual and going thru the commands...
Old May 10, 2020 | 05:15 PM
Originally Posted by BurakUsta
Hey Guys,
IDLE
CRUISE
WOT
https://youtu.be/Mx3cfrG6bI8
would the vehicle pass emissions test with muffler delete..especially in California?
Old May 13, 2020 | 07:10 PM
will175's Avatar
Can you post some pics of the exhaust after you did the mod. Sounds great in the vid.
Old May 13, 2020 | 09:07 PM
jerrym's Avatar
1955 300SL
if the catalytic converter isn't removed and just the resonator for the muffler. it should be fine..
Old May 14, 2020 | 06:42 AM
Kwesi400's Avatar
AMG G63
Hey Guys,
IDLE
CRUISE
WOT
Love it! I am also thinking about deleting my muffler. Would you mind posting photos of how yours was done? Like under the car? Is it still a Y set up? (1 pipe turns into 2 side pipes)
thanks in advance
Old May 14, 2020 | 04:19 PM
BCMgunner's Avatar
2019 G550
Any drone?? When mufflers are removed, it is a common complaint.
Youve got me wondering what a G550 would sound like without the muffler🤔
Old May 14, 2020 | 04:25 PM
Bob Z.'s Avatar
Easy to find out - just loosen it at the connector forward of the muffler, on both sides, separate the piping and start her up! Should take less than 5 minutes.
Old May 15, 2020 | 06:15 AM
BurakUsta's Avatar
Ferrari 458 Cls63
Actually, its not that easy to understand drone level because when you run the car without any pipes the sound coming from the cats are quite distorted and unbalanced.
Without any pipes, car will have more drone and unnatural sound compared to a pipe trough cats to tips.
With straight pipes from the cats, you will not have drone, i am %100 sure.
Old May 15, 2020 | 08:57 AM
Bob Z.'s Avatar
Good point, that part did not dawn on me; however, one can still get an idea of the sound at idle that way, especially when sitting inside with the windows up.
