20 G550 Speaker rattles
I’m pretty frustrated right now.
Just picked my G up from the dealer after it sitting there for 5 days to diagnose speaker/panel rattles in the front door.
Service tech starts by telling me that he thinks my iPhone is the issue..HUH?!
Also says it could be the network or the Bluetooth settings.
Evidently MB tech goes straight to coding or software issues and doesn’t look at physical observations.
I went to engineering school and have worked on audio systems before, even done custom install. I know what a resonating door panel or speaker grill sounds like.
So I get to the dealer to pick up the truck and I was able to reproduce the issue multiple times with multiple phones and several songs with the service advisor in the vehicle with me but MB is basically saying it’s not an issue or the issue is due to my phone.
I get home and fire up my tone generator app and I get substantial resonance at 70-80 Hz and also at 138 and 210 Hz.
It seems that MB used the door panel and cavity as the speaker enclosure for the mid speakers in the door and there is something loose inside both doors.
I’m about ready to just go get some dynamat and pull the door panels myself. Pretty ridiculous for a $145k new vehicle.
Seems common sense and ability to observe and diagnose is out the window these days at MB.
Now that my rant is over, question is, anyone else have this issue and found a solution short of insulating the door panels?
IMHO, you are dealing with two issues. One, the new G platform is still in beta so there are still many quality/design issues to be worked out and, two, MB's current attention to audio detail is simply abysmal. Their audio systems are designed to be nothing but background "filler" as exemplified by the fact that they still use a 30 year algorithm to implement their annoying (and non-defeatable) speed controlled volume. Turn things up to a nice level at a stop light, and the speaker cones will be popping out at 60 MPH. It's a disaster.
The non diagnosis was delayed due to their diagnostic system being down. They told me they needed to connect the vehicle to diagnose the issue. I knew things were not going to go well at that point.
Me, I get out a tone generator and figure out the exact frequencies that are resonating the door panels in about a minute. Only fix is to dampen the enclosure but the “techs” can’t figure that out in 5 days.
A well designed audio system should have enough vibration deadening to keep resonance at a minimum for any frequency the system can produce.
In both Mercedes New Car Warranty - and especially with Mercedes Certified Warranty - MBUSA takes a "more active" stand on warranty/process/approval.
Yes - with the "enclosure" design of the speaker cavities - like with any designed auto enclosure - there will be resonance frequency points - especially at volume.
A Mercedes dealer service dept - and frankly the Mercedes Warranty Service process - is simply not oriented to diagnose or address this as a "issue." The only area they possibly could address - is a defective speaker - or defective speaker mounts/assembly.
If you choose to pursue solution - I would first check to see if any owner, or any audio shop, has posted a video guide to door panel removal, and just like any custom mods to a manuf's entertainment system - a competent Audio Specialty Store might be able to insulate/add-deadening to lower the frequency or eliminate the resonant frequencies.
"Consumer G's" are about 27% of MY20 production - "Utility G's" make up the other 73% - on the "issue" side ALL world-wide warranty data gets "data dumped" back to MB Engineering and Magna weekly which is the way it should be..
I am not part of that flow.. from what I've seen or heard so far mechanical issues have not been endemic..
Unbelievable that it’s taken this long for them to come up with a solution I suggested weeks ago.
I’m pretty dissatisfied with my ownership experience MB!
Not the best experience so far.
BTW, it is both doors panels and it has been recognized as an issue now after 16 days in the shop. I’ve owned the vehicle for a month now and it’s been back at the dealership for more days than I’ve driven it.
W/in first 1K miles - broken multifunction camera, multiple dynamic seat issues (I think 3), window trim falling off, window still rattles, speaker rattles, door handle creaks, etc.
Honestly, while the issues are ridiculous, it makes sense as automakers use cheaper and sh*ttier materials in new cars for cost savings...
sounds like the G is your daily driver! How is it holding up after 36K miles? Any surprises?
Overall it is an amazing car, but when I step in a new Cayenne Turbo or other higher-end SUV's I can't help to notice the build quality is lacking somewhat.
