Annoying Warning
Old Jul 9, 2020 | 08:27 PM
spourreza's Avatar
mclaren 720s
Annoying Warning
Hi Guys, every time i stop at a red light or stop sign etc... i get this annoying warning that say to be aware of surroundings (or something to like that) and the 360 camera turns on!!! how do i shut this off on my G63? its so annoying...
Old Jul 9, 2020 | 10:02 PM
NikBenz1's Avatar
G
I haven't experienced that yet. Did a little research but couldn’t find any info on how to disable.
What’s annoying me is the auto lane assist or whatever. If I try to avoid a pothole and veer to the right or left (over the lines) the car breaks and or forces it’s way over to be inside the line. It’s freaking me out and I hate it. I tried to adjust the settings to standard as opposed to adaptive and it still does it. Anyway to completely shut off?
Old Jul 9, 2020 | 11:37 PM
whoover's Avatar
'19 E63S sedan
It sounds like one of your Parktronic (proximity) sensors is bad. See if any of them picked up a stone chip. In any case, Parktronic needs to be scanned to find the bad sensor.
btw, you can't turn it off. You have to fix it.
Old Jul 9, 2020 | 11:46 PM
jamesszzz's Avatar
G63s and a few others
What year do you have? MB must have disabled this in 2020 models. My lane assist does not work at all in my G, have had it for 3 months now and it has never corrected me whereas it’s a daily occurrence when I drive my Range Rover.
Old Jul 9, 2020 | 11:50 PM
G-Dreaming's Avatar
2020 G63, 2016 Range Rover LWB
Unfortunately it works very well in 2020 models. Be thankful yours is broken...
Old Jul 9, 2020 | 11:52 PM
G-Dreaming's Avatar
You cannot permanently shut it off. Just press the button for two seconds when you first turn on the vehicle to deactivate. Sometimes I forget, but not for long.
Old Jul 10, 2020 | 12:21 AM
Festertester's Avatar
‘13 911-4S, ‘21 CTR, '22 GT4, ‘19 G63
I don’t know what the mb workshop did after annual service the lka Intervention is much gentler now, I don’t even bother to turning it off
Old Jul 10, 2020 | 04:41 AM
NikBenz1's Avatar
G
which button do I press for two seconds to deactivate?
Old Jul 10, 2020 | 06:57 AM
spourreza's Avatar
mclaren 720s
Hi Guys - its brand new car with 300miles on it (2020)... you should there isnt a button to press to lower the sensitivity? every time i go to a stop sign or red light, be aware of surroundings comes on and it triggers the 360 camera...
its a new car, can it be a bad sensor or is there a setting to lower the sensitivity?
Old Jul 10, 2020 | 08:50 AM
jamesszzz's Avatar
This happens to me to me often too.
Old Jul 10, 2020 | 08:51 AM
pateljb's Avatar
2009 S550 4Matic 2009 GL 550 2009 AM DBS
I have a 2019 G63 and we had the same issue on the right front that would go off at stop lights or stop signs about 3 out of 10 times. At first they thought it was a bad sensor but sensor was fine so they re-flashed the software and then it got worse 5 out of 10 times at stops. Took it back to service and they kept if for 2 days and after working on it they found the issue was the right brush guard/bullbar stuck out 5mm furhter when compared to the left. So they adjusted the bull bar by moving it in so to be even with the left side and problem solved. We've been driving it for 2 months after this fix and no more warnings.
Old Jul 10, 2020 | 08:58 AM
whoover's Avatar
'19 E63S sedan
There's no way to change the sensitivity that you can do. The dealer has a calibration procedure, which they have to perform when they replace a sensor. I would just take it in. They will find a sensor that either failed, was damaged or is miscalibrated. I had one take a tiny rock chip on a road trip and it drove us crazy. On my model, there is a Parktronic button that will turn it off, but only for that stop. I had to press it at every light until we got home. I know it's very annoying. But the dealer will fix it and it will go back to just helping you park in tight spots.
Old Jul 10, 2020 | 10:59 AM
G-Dreaming's Avatar
Button on the far left just above the light switches. Vehicle inside two lines on the button.
Old Jul 10, 2020 | 12:24 PM
fpimd's Avatar
2020 G550
Hmmm, I like the bull bars on the 2019-2020s, but apparently:
  • On the G550 it’s mounted higher and you lose the front camera/birds eye view.
  • On the G63 it’s mounted lower, and based on this thread thereby increasing the chance of interfering with the proximity sensors.
Old Jul 11, 2020 | 03:36 PM
spourreza's Avatar
mclaren 720s
its definitely the two front sensors in the center.... so annoying
Old Jul 30, 2020 | 06:34 PM
spourreza's Avatar
mclaren 720s
turn out there is a bulletin on this. turns out that the glare from the bars reflect and camera senses an object nearby... they are putting this special tape to block glare and part arrives in 4 days. its a known issue on G63
Old Aug 13, 2020 | 12:37 PM
spourreza's Avatar
mclaren 720s
guys update: its a software upgrade. anyone dealing with the overly sensitive sensors in front, there is a service bulletin and its a software upgrade
Old Sep 3, 2020 | 03:59 PM
G-Dreaming's Avatar
At the dealership right now trying to get this exact same problem figured out.
Old Sep 3, 2020 | 08:01 PM
spourreza's Avatar
mclaren 720s
mine figured it out. they replaced entire module and now perfect... they need to replace module. no issues since then
Old Sep 3, 2020 | 10:38 PM
Bob Z.'s Avatar
'27 EQG deposit, '22 F8 Spyder, '20 Fat Boy
Can you post the part# from your work order? It would be good to know for those that have the problem now or in the future.
Old Sep 3, 2020 | 10:47 PM
spourreza's Avatar
mclaren 720s
i can call dealer. I threw out the work-order but they said they are replacing the entire “module” for the 360 camera for the two front sensors...
Here are the steps followed:
1- they thought the glare from the bull bars was reflecting onto the sensors and causing the beeps so they tried a tape to block glare... no go
2- they tried a software uprade which crashed... no go
3- they finally replaced entire module and now fixed.
its an open campaign and the suggestion is to replace the module... dealers should know this.
Old Jan 30, 2025 | 11:32 AM
Olzhas's Avatar
G63 2022
Hello, i have the same annoying issue on my 2022 G63, do you know whic exactly modules you replaced? only for 360 camera? or also parktronik main control unit as well?
