AMG Cylinder Manager g63 2020
Old Aug 27, 2020 | 10:29 PM
Amaterasu's Avatar
G63 2019
Hello.
Can someone please say in US spec g63 do you also have AMG Cylinder Manager that make car ride on low rpm/speed with 4 cylinders? (I think yes
Do you need to keep on start/stop function for that amg cylinder manager work?
Because in EU car you need to be on comfort settings and start stop must be turn on, if switch off then that cylinder manager not working. So I want to know is in US cars this function works same or not. Maybe I can turn off start stop by coding and keep that cylinder manager working without start stop function.
Old Aug 28, 2020 | 01:10 AM
dfulgo's Avatar
2020 - G63; RR.AB; ML350; ML320; ML400; M3; 200CE; 200E
...I'm in Europe and here it works in that way BUT why on earth it should be different? I mean, it's the queen of the "ECO" functions, if you turn them off...
Old Aug 28, 2020 | 06:32 AM
Amaterasu's Avatar
G63 2019
In US little different with start stop on all cars, its always have memory for start stop off or on, so maybe algorithm of work that cylinder manager will be also different and may allow to set off start stop and work
Old Aug 28, 2020 | 12:33 PM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
Cyclinder management only works if ECO mode is on. 2020 G63 USA here
Old Aug 28, 2020 | 01:09 PM
Amaterasu's Avatar
G63 2019
So also only with start stop turn on, right?
Old Sep 3, 2020 | 03:33 PM
Amaterasu's Avatar
G63 2019
Is there any way to make cylinder manager work without start stop? Maybe some piggyback?
Old Sep 3, 2020 | 06:59 PM
Bob Z.'s Avatar
'27 EQG deposit, '22 F8 Spyder, '20 Fat Boy
Did you try to put all the settings in Eco mode and manually turn off ***?
Old Sep 4, 2020 | 06:11 AM
Amaterasu's Avatar
G63 2019
Yes, if in comfort (eco mode) turn off *** it also turn off that cylinder deactivation function, I read about some piggyback devices that make car think it turn on but deactivate *** function
