Aux Fan Issues (I think)
Anyway, it is about 90 degrees here today, I turn on the truck, turn on the A/C, and the aux fans do not come on. Eventually they turn on in “super jet engine takeoff” mode. Very loud, but also this is when the A/C blows cold.
I drive around some and the aux fans turn off and the A/C warms up....this cycle continues on and off.
1). From what I read, the aux fans have a low and a high speed, it appears my low speed is not working properly....?
2). It appears the aux fans should be on whenever the A/C is on? (I also saw some opposing information). Regardless, I wouldn’t think they would turn off completely when the a/c is on and it is 90...
3). What triggers the low speed aux fan to turn on?Where is it located? I found 2 relays under the dash, but one is for the right fan and the other for the left....so I am assuming they are not the issue, as they are supplying power and both fans are operating in sync.
Any help would be appreciated...
Thank you in advance!!
I attached some pics of the fuses I think are associated with it...
I checked those and they were good. Perhaps I am checking the wrong ones....
I visually inspected 30 & 41 as my multi-meter is mia, they appeared fine. However, I better buy (or find) my other one to confirm.
i really appreciate your help.
