Do Door speakers, Horn and Door sills share same fuse?
I think i might have shorted a fuse while taking off the steering wheel airbag to take a picture of the steering column (Am having a custom steering wheel built in Latvia).
Been searching for days with no luck. Looking for the fuse diagram and location for 2013 G63.Found videos on 2002-2007 fuse diagram and locations but when I popped the panel on side of the dash towards the left of the steering wheel I don't see any fuses.
Does anyone have any idea if they all work with same fuse? Can someone please post the fuse diagram if they have it?
I might as well start with checking the fuses before trying to take these parts off.
Also, it is unlikely that the horn and the door sills share a common fuse because the door sills require a power source that is "hot" all the time while the horn is switched circuit with the ignition (via the front SAM).
As for the horn, did you make sure that you re-connected everything inside the steering wheel when you put it back together?
Lastly, you shouldn't work with the air bag with the battery connected so as to prevent accidental deployment and/or setting controller error codes. Always disconnect the battery for at least 15 minutes (to allow for the internal capacitors in the controller to discharge) before working on one (an you won't blow any fuses either). .
I just went back and realized its not just the speakers in door. The driver side front speaker on top of the dash is also not working. Meaning its ALL 3 driver side speakers that are not working. I doubt it is the speakers at this point. I used the balance/Fader and no sound from them. The door sills probably have nothing to door with the speakers. Might be a coincidence. But its weird that both sills on driver side not working. Hence why i assumed there was connection between the speakers and door sills.
Am thinking the guys who installed my android screen might have messed something. I just cant remember if the speakers and sills worked properly before the install so i don't want to pass blame right away.
As for the horn, I didn't take out the airbag completely. I didn't unplug it. I just released the springs and held it so i can take a pic for required for my build, When i plugged it back It went off like an alarm and when it finally stopped it wouldn't sound anymore. Once i step out in a few minutes, i will turn on the Audible Horn Lock sound feature to see if the horn sounds when i lock the car. Except if there is a separate horn for that sound, that should indicate if my horn is blown or not and help narrow down the issue.
Didn’t even have to get that far.
as I removed the door sill that wasn’t working , I noticed corrosion around the connectors. Turns out the wires were corpses and connection Wasn't being made.
cut off the connectors, joined the wires together and voila it lit up. Did the same for the other sill that wasn’t working since I noticed corrosion at the connector too. Success again.
will look for a way to connect the wires properly tomorrow.
Am happy one problem is solved.
Now to look into the driver side speakers that are not making any sound.
The audio issue ended up being that my amp was defective. I sourced and installed an interchangeable amp from a GL (E , C, GLA and some other models also share same amp) and voila the sound now works from all speakers.
however, am Not sure if it’s my mind playing tricks on me or if my ears just have to adjust to the out front all speakers but it sounds noticeably lower compared to when only my passenger side speakers was working.
do the interchangeable amps with these cars have different power output?
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
As for the replacement amp, are you sure it is compatible with the G sound system? The main reason why I ask is because the G speaker configuration is very interesting/unique. I have not seen anything like it before and had a lot of difficulty figuring the system out when I replaced the speakers and designed a custom amp setup. The front door speakers are wired to the tweeters. Then both L and R tweeters are wired to the center speaker. The rear door speakers work together with the bench sub to create a 'simulated sub', and the rear cargo speakers are just normal. No idea if this is normal for this era MB models but seems pretty odd to me.
I have not been able to find any information on the total power output of the OE G-Class sound system and I searched for that info for a long time. HK and MB also do not have this information through their customer service portals. Also what are the details of your aftermarket head unit setup? This may be different than the OE system in terms of system volume.
Now am not sure if the tuning of the W463 amp and speakers is different even though the interchangeable amp works albeit with less quality audio.
Luckily i didn't spend a lot on the new amp. I will find an exact W463 amp and see if that fixes it all. Or maybe the interchangeable amp needs to be reset or fine-tuned to match the W463 speakers...Not sure at this point if thats even a thing.
I have the OE amp from my 2005 but I would guess the amps are not the same between my earlier and your later G.
Is there a way to reset factory amps?
If it is the case that it’s in the amp and has to be adapted, am guessing that would be with MB star?
meant to exhaust these options before proceeding to source another amp uneccessarily.
If you can do it, I would be curious to see what you find. If the cabin/chassis is set as the donor car, then the info is stored in the amp and would an SD system to adapt.
Scrolled to the 7.8 in audio parameter and Everything looks just like yours. Vehicle/Cabine shows 463 W.
I went to the next parameter...7.9 which is EQ parameter and found it to be empty. Pics below. Does that mean the amp is currently adapted to Its original car and needs to be adapted to be adapted to W463?
I would appreciate greatly if someone can check and post a pic of their 7.9 parameter. Would like to see if it’s empty like mine as in my pic below or not. Would give more insight to the situation. And let me know whether I need SD to update the 7.9 EQ parameter to w463. That might be the solution to my issue.
Thanks in advance
I couldn't config the new amp so i ended buying another used one on eBay. The part numbers were identical and it was from a CLS63.
Happy to say sound is up to par now.
