35" tires on 2019+ G63? Anyone able to do it successfully?
The wheel fitment is critical, and I'm running a 10.5" wide wheel with 35mm offset, and 23mm wheel spacers. That barely allows for tire clearance on the knuckle, so I can't run less wheel spacer to pull it in without the tire hitting the top of the knuckle.
update: I sent your pics to a fabricator I have known for 30 years and have asked him for some info/guidance
Any help would be great.
Its a 2020
I emailed gwagenparts.com earlier as they sell multiple kits and one of their portal axle kit makes mention of new ABS sensors. Reading it seems to imply these can resolve the errors so I have messaged them for insight on if so can I buy the sensors and add them to the Eurowise 3.5 kit I am looking at. Or perhaps it just needs new sensors due to the portal setup. Also their Eurowise 3.5 kit page makes mention of "You can adjust the level sensors to trick the vehicle to see its not lifted" but there is no insight on this, and that note is preceded by the whole over 33" is an issue. Really think gwagenparts.com can clarify better as Eurowise and 3WDist weren't much help on the kits they have.
https://www.gwagenparts.com/product/...550-g63-w463a/
There is also this in a FAQ page:
and this is noted about the 4" lift kit but isn't clear on if its the 2018 or older
I am totally fine with 33s on a 3.5" lift but still read about rubbing front inner fenders so trying to pick 20" wheels to run 305/40s but may have to be 285/55 to avoid rubbing or if could 22" wheels with 35s.
