powering dash cam and radar detector
I've hardwired both camera and V1 in my current vehicles using the overhead console, so it's likely possible but no instructions that I have seen have been posted.
Also, didn't quite understand your last sentence--how did you mount your radar detector and dash cam? a pic would be great
I also want to avoid using a suction cup.
For the dashcam's physical mounting, I removed the plastic cover the encloses the radar/camera assembly above/behind the rear view mirror. I removed the suction cup from the dashcam's mount, and drilled 4 small holes that align with the air vents in the radar/camera housing. I used four #2-56 screws/washers/nuts -- these screws slip through the air vent louvres without drilling. The photo below shows the inside view of the plastic housing with the screw locations prior to re-installing. The dashcam weighs only a few ounces, so it hardly stresses the housing. I did this electrical and mechanical installation so that it could be undone without evidence of ever having been installed should I ever want to remove it.
