air leaking into cabin @ high speed
Old Dec 20, 2020 | 11:03 PM
saquarebox's Avatar
G
21' G Class here. When I drive on highways, I can feel cold air flow (presumably from outside) when I put my hand near the door seal. Do you guys also experience this? I wonder if it is due to the exposed gap between the door and the frame. I have never experienced this in other cars and they all have a rubber seal between the door and the frame that cover the gap.
Old Dec 21, 2020 | 09:02 AM
streborx's Avatar
Top Answer: 1
G550
Post a pic - maybe you 're missing a section of seal.
Old Dec 21, 2020 | 04:02 PM
Craig B's Avatar
2025 G 63
No, I haven’t noticed that at all.
Old Dec 21, 2020 | 10:37 PM
Bob Z.'s Avatar
'27 EQG deposit, '22 F8 Spyder, '20 Fat Boy
Mine is like a vault. If you vape or have a bud that does have blow a cloud where you think it is coming in and then look around unless of course you can see what the problem is.
Old Dec 21, 2020 | 11:26 PM
ItalianJoe1's Avatar
2003 CL 600
There were bulletins about cabin sealing on the new ones when the body updated, but from what I saw they were related to odd air pressure noises due to it sealing much better than the old style. Might be worth a dealer visit, it may not be normal and might be a simple fix.
Old Dec 22, 2020 | 05:40 PM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
No issues like this on mine.
Old Dec 24, 2020 | 12:39 PM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
No air leaking into cabin, but I had whistling. The seal around the window had to be replaced, which involves taking the whole door apart. The seal took a few weeks to arrive too
