2018 G65 amg front wheel wont come off
Old Feb 9, 2021 | 09:57 PM
ouli0826's Avatar
g65 amg
hi all ive just experienced a flat tire and trying to spare tires but after jacking up the car and taking out the 5 bolts the wheel is still stuck and wont come off. is there any way i can take the wheel off?
Old Feb 9, 2021 | 10:11 PM
E55Greasemonkey's Avatar
This place is a joke.
Typical corrosion on the hub. You'll have to knock it loose. Be extremely careful if it's up on a jack. If you're at home spray some penetrating oil where the wheel meets the hub. You should have free roadside assistance from MB if it's a 2018, if you are in the U.S. (?)
Old Feb 9, 2021 | 10:26 PM
ouli0826's Avatar
g65 amg
thanks! i was actually at home so i thought id get it then drive it to the shop tomorrow so i just got serviced td, could that be something to do woth it?
Old Feb 9, 2021 | 10:37 PM
ouli0826's Avatar
g65 amg
are there screws(not the lug nuts) in the 5 small holes? should i remove them?
Old Feb 9, 2021 | 10:57 PM
No those 5 small holes are for the wheel alignment head to fit into when being serviced.
Old Feb 9, 2021 | 11:00 PM
ouli0826's Avatar
g65 amg
does it being stuck have anything to do with the fact that I just had my wheels aligned and rotated this morning
Old Feb 10, 2021 | 05:59 AM
streborx's Avatar
Top Answer: 1
G550
Maybe it means the shop forgot to do the rotation (lol). I had this happen on my Lexus about a year ago. Had to sit on the ground and kick the tire on opposite sides a dozen times before it finally popped. Be sure to put a couple of lug bolts back in loosely so the wheel doesn't end up in your lap. There are anti seize compounds you can apply to the wheel surface to prevent this but I don't know if they're effective. I've read that the problem is not corrosion but rather some amount of molecular bonding between the dissimilar metals of the alloy wheel and the steel hub.
Old Feb 10, 2021 | 06:48 AM
prktkljokr's Avatar
12 C200, 12 C180, 10 Fuso Warrior crew cab, 08 RTV ute, 05 Smart Fortwo cabrio, 09 Smart Fortwo
I come across this all the time, I just sit down and give the tyre a good boot with my heal at the top, 9 times out of 10 it comes off first kick.
Good luck
Old Feb 10, 2021 | 11:29 PM
z168's Avatar
3phase-4pole
Good luck
^ this
I usually pick the 3 and 9 o'clock positions on the tires. it will come off
Old Feb 11, 2021 | 03:34 AM
084runnerltd's Avatar
2021 G550, BMW X5M, 2020 Toyota Supra LE
Time for a mule kick
Old Feb 11, 2021 | 09:53 AM
Limey Hooligan's Avatar
2012 G550 - Capri Blue Metallic
My Mercedes tech told me the same - although he mentioned "galvanic corrosion" it's some kind of dissimilar metal bonding or welding.. So apparently it's good practice to put some anti-corrosion element (spray, paste, film, tape) between the hub and wheel before mounting.
Old Feb 11, 2021 | 12:22 PM
mrtonyn's Avatar
1999 E320, 2008 S550, 2016 G63 AMG
It happened on my S550 and thought something really bad happened to caused the prevention of the wheel not coming off.
Depending on the severity of “bonding”, kicking it hard will not work. I did precisely that and it would not work until a rubber mallet was used to separate the wheel from the hub.
Went to America’s Tire to replaced the tire the next day and found out they use a very LARGE mallet precisely for this purpose.
The technician mentioned European cars and American trucks tend to have this metal bonding issue.
Add a big rubber mallet to your car’s tool kit 😁.
