Tire Recommendations
Old Dec 1, 2021 | 01:23 PM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
I want to put some 275/55/20 AT tires or other size that will fit on my G55. I will be using 20x9.5 G63 replica wheels. They have a 48mm off set. I have 17mm wheel spacers on the front and 20 mm spacers on the rear. I may put 30 mm spring spacers on the front to level the truck. Looking for recommendations on the size and type of tires. I’m in Florida so I don’t have to drive in snow. I don’t plan on any serious off road trips just some trips to the beach and some forest preserve drives. I like the aggressive look of the AT tires. Thanks for any suggestions.
Old Dec 4, 2021 | 07:35 AM
The Butcher's Avatar
G63, G65
I'm not awake enough to recall the factory G55 offset, but generally speaking, if you do a 30mm spring spacer you can clear a 33x12.50 tire without issue on the street. The only thing you might have to play with is the wheel spacer on those replica G63 wheels. I just went through this drill with another G63 that had 33s on factory wheels, and I want to say we ended up with a 21mm spacer on the front wheel to clear the steering box arm at full turn. The fatter tire was rubbing on it when you went full lock. The wheel spacer got it far enough off the arm to not rub, and it cleared everywhere else. The G55 might sit a touch lower, but if you do a 30mm spring spacer I think you will be fine. Lots of options in 33" AT tires. I personally like the Toyo AT2, and the new Mickey Thompson Baja Boss AT. The Mickey has a nice aggressive sidewall pattern. They make lots of options in the Baja Boss around 32"-33".
275/55r20 (32x11.00)
275/60r20 (33x11.00)
285/55r20 (33x11.50)
295/55r20 (33x12.00)
33x12.50r20
305/55r20 (33x12.50, but load range F)
You could play it safe and go with the 275/55 size, or make it a little more aggressive with something like the 295/55 or 33x12.50. Or, something in between if you are concerned with rubbing.
Old Dec 7, 2021 | 12:45 PM
I ended up getting 275/55/20 Ridge Grapplers. Thanks to the forum I was able to make an educated choice.
Old Dec 8, 2021 | 08:05 AM
streborx's Avatar
Top Answer: 1
G550
A sensible choice for size. Keep them balanced/rotated every 5K, and update us on how they perform for you.
Old Dec 8, 2021 | 10:53 AM
Have only driven a few miles but the vibration from the old flat spotted tires is gone. It definitely rides much better with the new tires. It looks more aggressive and there are no clearance issues. If anyone wants a set of the 19” wheels I have a flawless set that only were used for just over 5000 miles.
