G63 steering vibration from 60 to 70
ihade problem with my 2016 g63 amg when the speed reach 60 start vibrating can fell it in steering wheel mostly in early morning but after i drive it for more distance the vibration it come less and some times gone
i check all suspension systems
new tire
i check also the balance for rimes it’s perfect
any one get that problem before
new tire
https://www.cars.com/research/merced...-2016/recalls/
Based on your description, I would venture to guess it’s flat spotting on your tires from sitting overnight. This is exasperated by cold weather (typical in mornings as you mentioned it more often happens). Once you drive to get them up to temp, they are back to being round.
Happens to mine, and I can’t think of any suspension or driveline cause that would go away when warm.
my 2018 G550 did this too and I took it to a local specialist store that does custom alignments and wheel balances per recommendation of another forum member to get the tires trued (shaved to be perfectly round) and road force balanced. The shop did not think truing was needed but re did road force balance and the shake was gone on the almost 100 mile drive back.
might want to have another store re do the road force balance. I took it to a dealer twice who claimed everything was normal and rebalanced the tires with their road force balancer. What a waste of time and $200!
I assume your truck did not used to do this right? Some road feel is normal given the Wide tires.
Mine usually goes away after the tires warm up or I speed up to about 65/70 mph. It's just a quirk unique to G's.
I have the same problem, completely randomly. Various speeds, sometimes for a minute, sometimes for 10 minutes. Sometimes at 70 km/h, sometimes only over 110 km/h. Must be the tires, depending on wear, how long the car has been sitting still, ambient temperature etc.
